Coolant leak at firewall rear of engine
Hi everyone
My 2009 W212 E250CDI has a coolant leak from the plastic elbow that goes thru the false firewall at the rear of the engine. Can anyone help with a part name or number, and a procedure to remove and replace?
thanks in advance.
cheers
Hi everyone
thanks in advance.
cheers
There are 3 to 4 items , depending on engine model.
Try here, use your car VIN : https://nemigaparts.com/cat_spares/
The arrangement as follows :
01. Plastic pipe A from rear of engine. Pipe A.
02. Plastic pipe B. Some engine only have Pipe A and not B.
03. That hose in the photo, hose 1 of 2. From plastic pipe to firewall
04. The hose 2 of 2 which will receive hose 1.>>> This is firewall to HVAC heater core.
If you want to be safe, change all 3 or 4 of them.
