replacing battery
I think lot of chain service stations made a policy of not touching MB as older models had batteries mounted under the seats and not only yesterday's burger flippers could spark them on installation, but occasional reverse cable hook up ended in big bills for electronic modules replacement.
It is much easier on W212, although lifting heavy battery over the fender require some strength.
Just triple check correct cable installation.
Original MB battery in our case was also an AGM made by Varta.
Now flooded models are no longer available, when AGM models start at $250.
If you live in a mild climate, I wouldn't bother with a group 49, but if you live where it gets super cold, the extra CCA can help start on a coooold morning.
All my diesel engines (beside Ford T) start immediately and I think cigarette pack-sized booster battery would be all I need to start them. Even when I stored my black W212 for 2 years before AEM and sale, it did start on 1st turn after the long storage. Sprinter routinely sits 1/2 year without starting between seasons and no big CCA is needed.
