Sponsored by: CARiD
220 2012 turbo problems
Old Feb 17, 2022 | 04:10 AM
erling66's Avatar
mercedes W212 220 and vito w639
Hi I have a 220 sedan 2012 and the engine warning light came on and the car has lost most of its power. I connected a bosch code reader and got these error codes: P029900 (Turbo pressure 1 to low) and P024872 (low pressure turbo exit 2, component does not close) and P068501 (relay clamp 87 electric error)
Has anyone experienced these problems and know what I should do?
Old Feb 17, 2022 | 12:49 PM
Dane500's Avatar
2013 E550 Sedan, 2005 E500 4matic Wagon
Reads like a possible failure of the wastegate solenoid. If it is stuck open, then the turbo will not build boost. In my experience (not with merc) a solenoid is fairly cheap.
Old Oct 17, 2022 | 02:41 AM
arifk's Avatar
1992 500E
@erling66 Did you track down the problem? If so, can you share what it was?
Old Oct 29, 2022 | 04:03 PM
serry's Avatar
Mercedes-Benz c220 163hp 2013
Did you track the problem?
Hi erling66, were you able to track down the problem? If yes, what was your solution?
