Sponsored by: CARiD
M276.9 lower oil pan leak
Old Feb 17, 2022 | 05:59 PM
mercerized's Avatar
2020 E450 4matic wagon
Hello
Recently replaced the sealant for the left front cover on the cylinder head.
Cleaned some of the residual oil and discovered oil collected on the lower oil pan.
Didn't see much if any oil on the sides of the upper pan, so, I'm thinking that the leak is at the lower pan. It seems like the oil was collecting on all 6 screws.
There's not much on the forum about the lower pan leaking.
Seems like an easy job. No gasket only the Loctite 5970 (003989982010). Reuse the screws and torque to 14 nm
This is the lower pan: https://mbworld.org/forums/e-class-w...ml#post7653576
Has anyone completed this job? Thanks in advance.
Old Feb 18, 2022 | 01:18 AM
Senecat's Avatar
1983 Nissan Shltbox
Probably axle seals.
Old Feb 18, 2022 | 11:00 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
best way to identify source of a oil leak is to clean things up, drop some fluorescent oil dye in the filler hole, drive a bit, park in the dark, and inspect things with a UV flashlight. if you don't see any leak, drive some more, look again. you can get the dye at any decent auto parts store. UV LED flashlights are quite inexpensive now.
Old Mar 21, 2022 | 05:17 PM
mercerized's Avatar
Since resolving the left cylinder head front cover oil leak, I have not noticed any oil on the lower pan.
