Sponsored by: CARiD
Distronic plus retrofit w212
Old Sep 26, 2024 | 12:33 PM
  #51
Sarun Musteikis's Avatar
Mercedes w211 e500
Originally Posted by Adwalker
Yeah, as far as i dived ino EPC you need camera, radar and video module, front main DTR, 2 rear radars, 2 front radar aaaaaaand ESP premium, at least it doesnt seem to need any wiring for the esp. And there is no code in this VIN for simple DTR, only the Active blind spot and lane keeping 237, 238 and the 233 Distronic PLUS, so yeah, you need everything to make it work
I actually have new camera, distronic radar, control module, steering column. Also there is blind spot in the car so do I really need new radars in the back? And about ESP so understand that I only need new device and there ar eno new wires needed for it?
one more question could you see what ESP module and what short range radar codes fits my car?
Old Sep 26, 2024 | 12:35 PM
  #52
Mercedes w211 e500
Originally Posted by JettaRed
Ha! That will probably cost more than the car is worth.
I actually spend like 400 on half of the stuff, so it is not that expensive
Old Sep 26, 2024 | 01:13 PM
  #53
JettaRed's Avatar
Veteran: Army
Really? Care to provide an itemized list? Maybe you only got the cheap half. You're going to spend probably $400 getting everything coded when the time comes.
Old Sep 26, 2024 | 01:25 PM
  #54
Mercedes w211 e500
steering column, camera, distronic and distronic module, basically need two short range and esp, coding is going to be around 200 if I will not learn how to do it myself
Old Nov 20, 2024 | 01:24 PM
  #55
DTU's Avatar
DTU
S212 350 cdi 4matic
Question DTR+ query
Heya there,
I just registered here specifically to ask you about your DTR+ retrofit project.
Have you also added the heated MB logo emblem in front of your DTR+ front radar? It was standard in the next version, the W213, however not by W212 facelift - as far as I know.
If so, how did you solve it? In case you did retrofit the heated emblem.
I was in a small crash and my radar/front mask was put out of commission. Now that I'm rebuilding it, I would like to add the heated DTR+ logo cover. I need to add the wiring harness and code it.
Coding and adding the harness is no problem, I would merely like to know (ideally), where to connect the harness to and if I have to write a bit of SW to make the heating operable OR if I can just somehow interconnect it with temperature sensors (IF temp under x°C, turn on this output on here to turn heating on..).
Thank you in advance, hopefully you'll read it
Best regards
Daniel
Old Jul 31, 2025 | 04:21 PM
  #56
Mercedes w211 e500
Hi, wanted to ask about rear radar sensors my car and star diagnostic registers that there are b29/4 and b29/5 radars, but for distronic plus I need b29/6 and b29/7 radars, can you sugest on that? Will it just change to /6 and /7 when I activate distronic plus or would I need to change the radars or is there a possibility to just cahnge the component naming to /6 and /7? I hope you understand the question.
Old Apr 19, 2026 | 05:34 PM
  #57
haroun_zus's Avatar
Originally Posted by SUNILP
My vehicle came with esp plus. Premium is required for distronic plus.
Left connector is used in vehicles with distronic plus. Right connector from abs pump is from abs plus abs pump. I need to verify but if your vehicle is model updated (mopf) no wiring changes may be required at abs pump. I’ll verify this tomorrow.
Greetings,Great project! I am sure it took a lot of knowledge to accomplish the task.
Question regarding the ESP Connector from Plus to Premium, how did you managed the switch?
Did you re-pin all the pins from one connector to the other?
Thanks!
Old Apr 20, 2026 | 08:53 AM
  #58
o_Rage_o's Avatar
2015 E400 Coupe W207
Thanks!
I think that photo is only showing one half of the unit; when I purchased a used ABS premium unit it was plug and play with the abs plus unit I had, removed mine, swapped in place; no issues.
Old Apr 20, 2026 | 08:55 AM
  #59
o_Rage_o's Avatar
the radars that are used physically different for the rear, look similar, plug and play however.
Old Apr 20, 2026 | 08:57 AM
  #60
o_Rage_o's Avatar
Originally Posted by DTU
Heya there,
Best regards
Daniel
I did not get the heated logo; in order for this to work I believe there was also another small unit that controls if it turns on and off. I was on a e400 coupe c207 when I retrofitted the entire p23 package.
Old Apr 20, 2026 | 09:00 AM
  #61
o_Rage_o's Avatar
Also would it be possible to add only distronic without pre safe functio what i mean is without those two sensonrs in front bumber
I was able to get adaptive cruise working without the upgraded stereo camera in the windshield. Without the camera in the windshield only active lane keep assist was disabled.
I already had upgraded ABS module too
Old Apr 20, 2026 | 12:52 PM
  #62
haroun_zus's Avatar
Thanks for you reply!
Do you remember the part number for the Premium ESP you used?
I am trying to retrofit Distronic plus on a 2011 E350 4MATIC. So far the only "compatible", with my car, Premium ESP I found have the red, on the left on your picture, connector. The plug on y car is like the one on the right on your picture.
Thanks again for sharing the knowledge!
Old Apr 23, 2026 | 12:05 PM
  #63
need2speed's Avatar
2016 S212 E400 RENNTech 345 whp/360 wtq
I'm on a quest to decouple Distronic Plus proximity control from the cruise control, maybe someone who has added the feature can suggest the steps to reverse engineer it out? I've talked with two of the forum software wizards who both required an expensive membership as deposit before they'd look at the problem, with no guarantees.
I want to keep collision prevention and blindspot monitoring but, with our long winters, the roads are icy and snow covered or wet and sloppy from November to April (snow in the forecast today). When the Distronic sensors in front get dirty, it deactivates cruise control. On the highway we are not in a position to pull over every 15 minutes to clean them, especially in poor conditions when its most likely to occur.
Another issue when driving in busy highway traffic I would have thought was pretty common? The minimum following distance I can set with Distronic Plus still allows enough room for a**holes to pull in front, between me and car I'm following. Suddenly the brakes come on and I drop back, then a few minutes later another a**hole pulls in front.
Other features like Steering Assist I can deactivate. Its pretty useless when the roads are snow covered and it goes bonkers at traffic circles. Give me back normal cruise control!
