Sponsored by: CARiD
18" Wheel Fitment
Old Mar 12, 2022 | 11:54 AM
greekstylist's Avatar
W212 E550 4Matic, W211 E55 AMG
18" Wheel Fitment
Hi Guys,
I have a 2011 E550 4matic. Stock wheels 18" 8.5"wide et 48. Will 18"x8", 42 Offset, 5x112 work?
https://www.partsengine.ca/081384-vp-rtx-150.aspx
Thank You
Old Mar 12, 2022 | 12:21 PM
RA72825's Avatar
Yeah, they should be fine, but a $160 wheel? Better you than me. Good luck
Old Mar 13, 2022 | 11:27 AM
You are right. Too cheap. What offsets should I be looking at? The rims will be 18". Thinking either 8.5" or 9" wide. Also I know the hub size is 66.6 but can I use 66.56mm?
Thanks for the help
Old Mar 14, 2022 | 09:53 AM
RA72825's Avatar
There are dozens of wheel calculators on the web to help you with offsets. You can figure that out very easily. Do not buy a wheel that doesn’t match the specific Mercedes hub size without using hub centric rings or you will regret it. The wheel must be hub centric not lug centric.
