Sponsored by: CARiD
E550 V8 star on the engine cover?
Old Mar 7, 2022 | 03:56 PM
[Vlad]'s Avatar
2011 E550 P2 Pkg w/NightVision
Hey, apparently, a star from my engine cover fell of and I hate how it looks! Does anyone know where I can order one or a part number for it? Also, does anyone know where I can order stock air intake tubes? Mine are starting to break!
Old Mar 7, 2022 | 06:22 PM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
That thing always falls. You are better off getting star sticker or something.
Old Mar 7, 2022 | 07:04 PM
W205C43PFL's Avatar
You might need to swap the whole cover, the part number should be A2730101967
Old Mar 7, 2022 | 07:54 PM
[Vlad]'s Avatar
Huh, interesting. but looks like the part number is a bit wrong. Since the given part number has the cover for the V8 but does not have the "bulge" that my cover has lol.
Old Mar 7, 2022 | 08:01 PM
W205C43PFL's Avatar
Sorry about that, is this it? A2730102267
If not, if you can please provide your VIN number then I will be able to confirm.
Old Mar 7, 2022 | 08:05 PM
[Vlad]'s Avatar
oh, no problem! Here is the vin: WDDHF9AB4BA504995
and thanks so much for helping
Old Mar 7, 2022 | 08:10 PM
W205C43PFL's Avatar
You are very welcome, happy to help. The part number for the engine cover should match the VIN you provided.
Alternatively, since you can't order that star separately (not that I am aware of) I wonder if you can buy one of the MB stars installed on the rear of the vehicle where the trunk is and put one in the 3 slots where the original one was on the engine cover, I wonder if the size is too big or too small.
Old Mar 7, 2022 | 08:14 PM
[Vlad]'s Avatar
Oh, good question! I think I can measure it and see! I'll check tomorrow and if not, new cover it is! Once again thanks for the help!
Old Mar 7, 2022 | 08:21 PM
W205C43PFL's Avatar
You're welcome
Old Mar 7, 2022 | 08:34 PM
W205C43PFL's Avatar
I will just throw the part number of your rear Mercedes star in case you need it: A2128170016
Edit: I was thinking since you can't buy the engine cover star separately, you could probably find a replica somewhere or if someone for some reason has an extra one they can sell.
Old Mar 7, 2022 | 08:40 PM
W205C43PFL's Avatar
Here is another thought
I wonder if the wheel hub caps will work
Edit: Just throwing some ideas, measure the one on the steering wheel too. This one is unlikely to fit but in case it does. Oh and the hood badge (not the standing star, the one on the grille I mean) too.
Old Mar 7, 2022 | 10:33 PM
Zavato's Avatar
2012 E350
I had the same thing- the star is not available separately- and this is a somewhat common issue
Old Mar 7, 2022 | 10:42 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
Same here ... It's too bad you need to buy the entire cover, but it bothered me enough that I had to replace it
Old Mar 7, 2022 | 10:54 PM
W205C43PFL's Avatar
What type of glue you guys used to make sure it doesn't fall off again?
Old Mar 8, 2022 | 12:51 AM
cetialpha5's Avatar
Pretty much any glue should work. My did break off, but I was just able to glue it back on, maybe it was gorilla glue. Also there are some MB's in the junkyard these days, I wonder if the star from other years/engines would work. Was at a few pick and pull yards last week, but many of them were pretty well stripped, lots of the smaller engine parts were gone and no sign of any MB hood star.
Old Mar 8, 2022 | 02:37 AM
BenzV12's Avatar
W212 FL
I didn't know those things could fall off lol
Old Mar 8, 2022 | 07:01 AM
hyperion667's Avatar
2012 CLS63
Old Mar 8, 2022 | 08:53 AM
W205C43PFL's Avatar
One man's trash is another man's treasure, a good place and worth a look to see what can be used for sure.
Old Mar 8, 2022 | 08:56 AM
W205C43PFL's Avatar
Ah, draw it back ?
Old Mar 8, 2022 | 08:57 AM
DFWdude's Avatar
2016 E350 Sport
Here is another thread on this topic, including 3D printed version replacements... I would let hell freeze over before I bought a whole engine cover (that no one sees) for an 11 year-old car...
https://mbworld.org/forums/e-class-w...ar-emblem.html
Old Mar 8, 2022 | 09:52 AM
RA72825's Avatar
^ exactly. Just buy a 3D printed version and epoxy it on
Old Mar 8, 2022 | 10:23 AM
W205C43PFL's Avatar
Does it melt though? Let me check the thread.
Old Mar 8, 2022 | 10:35 AM
konigstiger's Avatar
'71 Pinto
As mentioned MB does not offer star separately here is cover part # if looking to replace. Discontinued intake lines, read thread for work around using aftermarket: https://mbworld.org/forums/e-class-w...let-ducts.html
File Type: pdf
Old Mar 8, 2022 | 11:39 AM
DFWdude's Avatar
2016 E350 Sport
Local libraries often have 3D printers, some will have metallic reinforced plastic if you request it.
Also, check "Thingiverse" and search for MB star files. https://www.makerbot.com/thingiverse/
Here is a flat star that can be resized to the correct dimensions... https://www.thingiverse.com/thing:1552272
Old Mar 8, 2022 | 01:05 PM
W205C43PFL's Avatar
Thank you for the suggestion.
