Sponsored by: CARiD
Vibration when turning
Old Mar 27, 2022 | 04:53 PM
Joan12's Avatar
05 c230k sedan 13 E350 4matic
Hi I have a 2013 e350 4matic with the v6 engine, lately I notice that whenever I'm making a turn at anything lower that 20 mph the car vibrates, I check under it and around the tires and everything looks fine, it only happens at low speeds, either way I turn still vibrates, does anyone know what to look for or what I'm looking at, thank you
Old Mar 28, 2022 | 01:18 AM
toledotom's Avatar
2010 E350 4Matic
Check your Power Steering fluid level. Mine was low when it started doing the same thing. The vibration went away but 3 months later the Power steering pump went bad (front seal and bearing). Lost about a quart of $25 MB fluid. Hope yours isn't the problem? New pump is $375 plus fluid and installation. about 2 hours?
Old Mar 28, 2022 | 01:43 AM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
Power steering on these cars is electric.
I would check the power steering motor for loose insulation. I had to tape up mine because the factory wire insulation was coming apart, and may allow water intrusion.
Old Mar 28, 2022 | 08:28 AM
Senecat's Avatar
1983 Nissan Shltbox
Not all of them. See attached.
Old Mar 28, 2022 | 09:33 AM
konigstiger's Avatar
'71 Pinto
2013 does have direct steer. Since this is a 4matic most likely transfer case try this: https://mbworld.org/forums/e-class-w...ml#post8493244
Old Mar 30, 2022 | 09:02 AM
degeja's Avatar
2016 E350 Sedan SPort
check your main battery voltage; should be 12.5v or higher when sitting in gaarge in morning;
electric steerng can be erratic at low speeds if battery is going bad or battery connections need tightening.
Old Mar 30, 2022 | 11:21 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
I believe the '10 and '11 models have a power steering pump and the '12 thru '16 have electric.
Old Mar 31, 2022 | 01:45 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
As it was mentioned already.............. Most likely is your 4matic system. Have it check by an expert.
