Subwoofer box?
my 2010 doesn't have the backseat that folds down so was thinking of building a box in the area behind backseat for a 12" sub.
i searched around but couldn't find any pictures of custom boxes for this area. Has anyone put a sub box here?
I was thinking of using mdf at same angle as seat vertical, then mdf on floor until the taper down in floor, then use fiberglass for the transition and sides.
Mdf top at the height of the black bar with wiresThen have a flush front face in mdf, the box would end around the little hooks in the floor watching the arm for the trunk
Anyone have any comments on if this sounds like an ok build or things to watch for?
I have hk system, was gonna tap the 2 wires that plug into factory sub in the rear deck. I have the trunk battery so wiring should be relatively smooth.
I'm not making anything special. Here's the enclosure I threw together on subbox and am building now
https://subbox.pro/en/b/DTItgo4C6
I'm probably putting in an alpine s 12 and one of their amps.
I've made several sub boxes in other cars, had not done fiberglass before so I'm a bit hesitant to start learning with the Benz.
https://mbworld.org/forums/e-class-w...-complete.html
I was planning to have the face of my sub facing the rear of the car.
I think I'm going to try a technique I saw on YouTube, they used a bunch of mdf pieces and hot glue to make 90% of the box and fiber glass to seal the rest. I just got a big box from Amazon so going to use the cardboard to start tracing stuff this weekend
