Tire size question
I have a 2010 E350 sport sedan with 18 in AMG wheels with tire size 245/40/18. As cool as it looks, it is a painful ride over NJ potholes. I have also replaced the tires with run flats which doesn't quite help either.
Therefore I have decided to get 17" rims but I see the standard recommended tire size is 245/45/17 which is barely different from the current tire size.
Any recommendation on the biggest sidewall I can get 17s for this sedan? I just tried 225/55/17 (from an old S) and they fit. But before I buy new tires for the (old) 17inch rims, I would like to get some advice and recommendations. I do want to stick with the run flats though.
Thank you.
Dmad
Is yours a 4matic? If so you might be able to go down to 16". 17" is the smallest that will fit due to front lower ball joint clearance.
A little bit of sidewall height isn't going to make or break your situation, it's really bad to go super low profile on big 19" wheels sure, but the S class makes do with big ol' wheels these days.
https://mbworld.org/forums/e-class-w...ls-offset.html
Now, based on everyone's responses, I guess, using non run flats is the next best thing to do. I guess I will give it a shot.
The rims I have are from a 2004 S class... I think they will do just fine. Thank you
the stock 245/45R17 XL's, like the Michelin Pilot AS4 I'm running, have a load rating of 99, which is 1709 lbs per tire. The stock 245/40R18 XL are load rating 97, 1609 lbs.
and yes, runflats are *AWFUL*. my son bought a BMW 530xi that came with runflats, and replaced them with regular tires and the car rode and drove 10X nicer.
Non run flats with lower tire pressure would help significantly, try it.
Btw, did you say you tried 225/55/17? This gives bigger diameter than the normal/suggested tire size, if that really fits l suggest you go for it.
Right now I'm running 225/55/16 tires with 32psi, and l already changed the springs from 677 to 485 ( comfort) , l still don't 100% satisfy with the ride quality.
the 225/55R17 is 27.1" OD
thats a pretty big OD offset. 810 rev/mile vs 770 rev/mile. pretty big speedo and odo errors there.
I-287 has also claimed a few tires so I do understand your frustration.
I am keeping 16" wheels from W211 for potential use on W212, but I have good tires when we don't drive much, so probably another 4 years till my tires age.
I did not have good luck with 17" wheels. When human perception with comfort is pretty lousy, I think tire quality plays bigger role, than sidewall dimension.
Meaning I was happier with 18" tires and much bigger choice of tires.
My car does not have space for spare, but I bought donut-sized wheel from other MB model and am carrying it in the trunk. Driving 150 miles stretches between tire service on 120F desert is not making you want to wait for tow truck.
