Sponsored by: CARiD
Cigarette lighter in trunk
Old May 2, 2022 | 03:07 PM
yt4o's Avatar
E350
Hey, I have fuse 76 plugged, but its because I have cigarette lighter in the rear center console socket, so i will put Tap-A-Fuse in #72.
I already test "source" side of #72 and voala 11.82V when car switched to ignition (engine is off) and 0V when car switched off.
Mine W212 is WDD2120251A with engine: 642.850
P.S. By the way I'm a little confused because VIN number says: "Its model from year 2001, the car is ordered November 2009 and assembled and selled December 2009"
But in internet all W212 start from year 2010 to 2016 These one that start from 2001 to 2009 are W211, but my VIN says 212 ....
Old May 2, 2022 | 03:40 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
11.82V is low voltage, so either your battery is weak, or the circuit is having some resistance on its way.
Old May 3, 2022 | 01:35 AM
S-Prihadi's Avatar
Your VIN is not complete, it should be 17 digits.
WDD2120251A <<< yours only 11 digits
WDD2120656L037906 << mine
Glad your fuse 72 work. I too have cigarette socket at center console rear part under HVAC vent.
True to what Kj1 said, 11.82V is too low a battery voltage even for rear SAM.
Careful when doing electric works on the car where you need to sense voltage presence, there is a low voltage cut off at 11.8volt to many non vital devices. See attachment.
So charge your battery properly prior to testing or keep it charged while testing because car computer/s wake up condition can take easy 6 amps.
Old May 5, 2022 | 11:07 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
Lots of good info in this thread
Originally Posted by sweetnsassy
I I wish I could trade my ashtray for a 2nd 12V socket or for my car vacuum to clean the trunk after I transport a dead body of someone who smoked in my car.
Old May 20, 2022 | 07:40 AM
yt4o's Avatar
E350
Hello guys,
I mount the cigarette lighter and i made it better than factory one, also looks better Here are some pics::
Of course, now as a first impression I saw that the lighter only works when the engine is running
This is on fuse #71 plug. I will test it on fuse #76 for better results. Now when i switch the key, but not start the engine,
the lighter is on for about 30 sec, then i hear how relay turn off and also lighter is tuurned off (no voltage)
I hope fuse #76 will fix this.
I want to share one more thing with you, the Chinese Tap-a-Fuse is ill-conceived rubbish, because their hat, where the fuses are,
rests on the next fuse, where you plug Tap-A-Fuse on! Then the pins of Tap-A-Fuse not contact good with your car electical installation...
The workaround is to use smaller Tap-A-Fuse (for example plug in mini Tap-A-Fuse on standart socket) but his pins are thinner than standart and this is not good (risky)
And again thanks all for the hints and help, especially S-Prihadi
Old May 20, 2022 | 07:47 AM
DFWdude's Avatar
2016 E350 Sport
In reading your first post, I thought you wanted a switched circuit, to avoid battery drain.
As you have installed it, you have successfully found a switched circuit with fuse position 71. The 30 sec delay before it turns off is how it works.
IMO, it won't get any better than that.
Old May 20, 2022 | 07:52 AM
  #32
yt4o's Avatar
E350
Yeah I agree, but with switched key on (engine off) front cigarette lighters continue working (after these 30 sec) and
turns off when i completelly turn of the key and unplug it. This is better logic and is my goal that i aim
Old May 20, 2022 | 11:07 AM
  #33
Edward993's Avatar
2014 E350
Originally Posted by S-Prihadi;8557014
[img
https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/983x650/tap2_6185ce498c340efd037e7af35df585a9ad909bfd.png[/img]
Oh this little doodad is worth the price of admission! Never seen one ...thanks for posting this!
Edward
Old May 20, 2022 | 11:18 AM
  #34
Edward993's Avatar
2014 E350
Edward
Old May 30, 2022 | 10:57 AM
  #35
yt4o's Avatar
E350
Fuse #76 fix the 30sec turn off issue and now all working fine.
