Creaking Noise When Turning Wheel
Hoping it can cause the balljoint to produce the sound due to higher loading on it, while car is safe stationary for your inspection.
The turn happens inside the strut so could there be a problem inside the strut that makes the noise?
However, during my caster/camber correction bolts adventure I noticed even being a follower type ball joints (we use 2) at high steering angle and decent suspension travel , the balljoint has some load on it.
I agree the macP strut top side bearing is a good candidate for inspection too, sweet info. thanks
