2013 E350 Seat Belt Pre-tensioner Issues….
Thanks in advance
Belt pre-tensioners are built to be non-serviceable crash parts.
What DTC fault are you getting? These modules report and take orders on CAN-E1.
The safest way to go would be to replace the driver side with a part of your choice to restore safety. Any Dorman deal?
That being said I recall looking at that unit and deciding I was not going to trigger 1-way temper detections. I saw it's has a tiny belt with ribs like our electric steering rack. 3x bearings traveling on a plastic ramp are used to lock belt extension.
You can trust this German part to perform as designed and quit when supposed to. Hopefully codes will provide you with further info about what caused your troubles besides "replace faulty unit" -
The published TSB was dated 2012. Your MY13 could be affected based on assembly month.
Match software numbers using your scanner for peace.
