Running 19’s wheel fitment
Hello Everyone !
I was thinking maybe I could get some help..
Currently I’m running stock AMG wheels with spacers (15mm front 20mm rear)
18x8.5 ET48 245/40/18 squared
Friend of mine has some 19’s for sale (rims and tires) and I'm really digging the look of it… which are 19x9 ET35 255/30/19 squared
So I like the wide tires, I know sidewall of 30 is a bit too thin but would I be ok to run these on my W212 E350? Any issues might cause?
Maybe later on I’d run a different set of tires but for now since the wheels already comes with the set I’m trying to see if it can work
Any advice or input will help so much!
I appreciate you guys all
Yeah, those should work. You may have a slight poke up front with the 35ET and the 255 width. I’m running a 37ET up front on a 19x9” rim, but with 245/35. I’m using the OEM E63 AMG wheels.
Slight poke at the front.
E63 AMG multispoke wheel
pierrejoliat (05-26-2022)
My rear is a 285/30 on the 19x9.5 wheel. Pretty meaty.
Stock springs, no rub. No Airmatic
The only thing that is aggressive on your setup is the 35 ET in the rear. My wheels are 52ET, but I could use a 15mm spacer for a more flush fitment. You on 9” wheels vs my 9.5” wheels should put you right at the inside fender lip.
