Sponsored by: CARiD
Media screen
Old Jun 16, 2022 | 02:35 PM
Chelseaboy67's Avatar
E350 2010
Media screen
Hi I'm a new member and I really need some help . I have a problem with my media screen it won't work . I have tried everything that I can think of. Replacement of the fuses holding the cd eject button disconnected the battery. But still nothing got a replacement screen and that won't work.The auto electrician that told me I needed a new screen is now telling me I need a new radio. But the radio still works so how can it be that. Any suggestions .Thankyou in advance.
Old Jun 16, 2022 | 03:09 PM
konigstiger's Avatar
'71 Pinto
Find an independent with Xentry (MB diagnostics) to pull fault code(s).
Old Jun 17, 2022 | 03:47 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
There is a fuse in the wiring harness behind head unit, but I don't know if that's the issue.
Old Jun 17, 2022 | 08:54 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
the rear fuse would be a nice 50¢ fix !
I wonder if COMAND...
> uses a thermo-fuse to stop the head when the cooling airflow is restricted by the tiny filter?
> they use caps under rated at only 103°C or 16V ?
COMAND is assembled with hundred's of screws... to make any simple repair time consuming.
