Sponsored by: CARiD
Distronic plus deactivated automatically
Old Jul 4, 2022 | 02:23 PM
mostafa.ezzat's Avatar
e350
Hi guys I have e350 with distronic plus lately it’s deactivated all the time by it self for days and it’s again working normal for like 30 mins or hour and then it’s deactivated again and this deactivated adaptive cruise control and blind spot and pre safe break I replaced both batteries main and auxiliary with OEM ones and the issue still there scanned the car and found those errors and cleared them but the issue still there any ideas for this issue
Old Jul 4, 2022 | 02:57 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
front end faults...
Is that the exhaustive list of ALL active faults? Try not to single out these 3 front modules to consider ALL modules that are acting up.
Radars + ESP + ...
These being "stored" means it's not a hard fault but a part-time transient condition.
You can try to figure what these modules share that makes them actup: chassis bus, power...
One module can disrupt the bus and spoil coms for perfectly good units... you can disconnect radars to see if your ABS/ESP works normally.
Trust this particular module is not built to fall apart prematurely unlike the radars that are not waterproofed.
Has this car been repaired for a front collision ... radars?
Old Jul 4, 2022 | 03:33 PM
e350
Nope there was no front crash but the glass of the distronic plus is little bit cracked but it’s was working fine before even when it was cracked
Old Jul 4, 2022 | 03:38 PM
it used to be okay....
go ahead proceed by elimination... except ABS/ESP brakes
Old Jul 4, 2022 | 04:01 PM
e350
Replacing this won’t be cheap I already replaced both batteries and btw no problem from abs /esp
Old Jul 4, 2022 | 04:11 PM
you don't always need to just replace everything. MB are super well built for quick service.
Some of the questionable parts can be overalled easily...
Old Jul 4, 2022 | 04:22 PM
e350
Meaning ?
Old Jul 4, 2022 | 06:07 PM
up_too_late's Avatar
2015 E350 4Matic Wagon, 2018 GLE350 4Matic
Did you replace both batteries at the same time? I had similar behavior with non-communicating control modules and I had to disconnect both batteries at the same time to get the messages to clear. Disconnecting and reconnecting individually did not clear the error. This is when I had a weak main and was trying to nurse it along by regularly charging it.
Old Jul 4, 2022 | 06:45 PM
e350
Not at the same time the problem is it’s sometimes working and most of the time not working
Old Jul 5, 2022 | 01:16 AM
Meaning ?
once you find out the root cause of your part-time chaos, you may have options to replace or rework.
Old Jul 5, 2022 | 07:34 AM
RA72825's Avatar
If you have a multimeter I would check your new MAIN battery for its current state of charge and also it’s value while car is running and battery is charging. They sell weak or dead batteries from time to time and you may have one. Takes 5 minutes
Old Jul 5, 2022 | 04:22 PM
e350
i had an issue with eco before and after changing the battery the eco is working fine which means that the battery is good and its OEM battery
Old Jul 6, 2022 | 05:03 PM
e350
went to garage to check it there was no errors shown and they couldn't identify the issue checked the fuse in the truck it has no issue
