Sponsored by: CARiD
Reverse parking sensor
Old Jul 22, 2022 | 09:47 PM
yyce400's Avatar
E400 Wagon
Whenever I shift my car into reverse, I get a beep and the reverse distance indicators show 4 red dots, 2 on each side. I have an icarsoft MB2 scanner that I used to pull fault codes for the Parktronic module. The fault code that I'm getting is 927B14, however the scanner doesn't recognize the code and I can't find any info online. Has anyone run into this code? Am gonna take it to a shop on Monday most likely...
Old Jul 22, 2022 | 10:36 PM
Aussie_E350_Wag's Avatar
2013 E350 Facelift (Japan Import) 2007 E350 Elegance Wagon, 2014 E350 Wagon facelift model Jap Model
Maybe yours have been wet and have shorted out? I have read a few times they are not very water proof.
Old Jul 23, 2022 | 07:17 AM
RA72825's Avatar
Whenever I get that red light warning either in the front or rear it means a sensor is blocked with ice ( winter), or a sensor has gone bad ( summer). You probably have a failed sensor and need to isolate the rear sensor loom to find the bad one.
Old Jul 23, 2022 | 03:45 PM
konigstiger's Avatar
'71 Pinto
Different code, as suggested above check rear sensors/harness. See attachments.
Old Jul 25, 2022 | 04:51 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
First clean rear sensors with alcohol, then climb underneath and check wire connections,
Old Jul 26, 2022 | 04:30 PM
yyce400's Avatar
E400 Wagon
Update!
I took it to a friend's shop and they were able to pull the code and get a proper description. Strange that the MB2 couldn't pick it up, even though in that youtube video it's using the same thing...
Anyways it's the center left sensor, I can see it, but unfortunately I'm unable to reach it as I believe the tow hitch or something is blocking access. Going to buy a replacement sensor then pull the bumper.
Old Jul 26, 2022 | 08:43 PM
Originally Posted by yyce400
Update!
Glad to hear you've found the issue,
Woukd you be able to post some pics of pulling the rear bumper off if possible, they look like a nightmare to remove!!
Old Jul 27, 2022 | 03:00 AM
BenzV12's Avatar
W212 FL
Same here, nice to see you have found it , I think that must be the hardest part of the problems , fixing should be easier despite some glitches
Old Jul 27, 2022 | 08:58 AM
RA72825's Avatar
Glad you found the bad sensor. You will need to paint it to match your body color. Nice job!
Old Aug 6, 2022 | 12:30 AM
yyce400's Avatar
E400 Wagon
I will try! I ordered the sensor off ebay from a buyer in Lithuania, so it'll take a while to get to Canada. Will try to tackle it ASAP.
