Sponsored by: CARiD
Need Second Opinion
Old Jul 27, 2022 | 06:42 PM
ij818's Avatar
2012 Mercedes E350
Unhappy Need Second Opinion
Hello, my first post here is a bitter one, I am the owner of a high (144k) mileage 2012 E350 with the m276.
I took it in to get the common startup rattle issue fixed. Unfortunately, It is currently sitting at my local dealer, after being quoted 2k for chain tensioners, and later 6k to replace the cam adjusters, the dealer noted the vehicle is needing both camshafts and lifters (unknown if all or some) on one side of the engine.
Here are the photos
While obviously any type of pitting or uneven wear is bad, given the mileage, should I go through with replacing the cams/lifters? I understand the severity of having cams fail, but
that engine has 144k miles; I've only put 7k on it in the 8 months I've had the car!
Can I get some more insight! Thanks!
Old Jul 27, 2022 | 08:46 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
poor lubrication....
It's not just 4x camshafts... the aluminum heads have no replacable bearings for the dry steel shafts. Somebody drove that engine on oil fumes
4x camshafts
2 M276 engine heads
4x VVT
2x tensioners
4x oil solenoids
4x camshaft sensors
80% chance for "oil in the harness" neglect
No word about tired transmission...
Don't get robbed: add some engine snake-oil and trade it! Even my dealer says to ignore rattle, during warranty period.
++++ in addition : "bait and switch " BS ++++
The worse bank is the passenger one!
Showing you the wasted driver side engine head let's us imagine the passenger side. It always suffer first from low oil pressure caused by the amazing tensioners leaking oil pressure.
Old Jul 28, 2022 | 08:37 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
So that's $6k to just start engine restoration, when we don't know how much a new one would cost?
I am hearing on Sprinter forum that rebuild diesels are supplied by dealers for $8k
Old Jul 28, 2022 | 09:07 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Yeah agree would look into price of rebuilt engine to throw in there. Gotta be cheaper then going the half way route, they will try that to milk as much as possible.
Old Aug 15, 2022 | 04:58 PM
Blkvip's Avatar
12' E559
Ditto, never go to the dealer if you dont have to. not sure what part of Mass youre in. if your local to Waltham, check out European Auto Solutions.
Old Aug 16, 2022 | 02:14 PM
Aktash's Avatar
S212
that sucks, I got my tensioners and check valves in the trunk as well was planning to get them done this thursday at my indy shop, along with some other routine maintenance. I am at 150k. Depending what you paid for the car and how attached you are to it, I'd button it up an resell or drive till it starts making some serious noise and swap the motor for a lower mileage one.
