Abs, Esc, Traction Off. Blind Spot, Cruise Control inoperable
the advisor at merc said could be your rear radar sensor, unplug check that and if that doesn’t fix it, come back again
been reading the forum alot but just felt the need to make an account now
throwing codes p2006, 63F900 and +1
You need a better scanner that matches your car to read ALL modules. Right now the modules faults causing dash messages is not shown.
Wheel sensor is a good candidate and a dozen other things after that because "BlindSpot" is not wheel related.
