Sponsored by: CARiD
Engineering mode
Old Aug 11, 2022 | 05:24 PM
123jaye's Avatar
E class s212
Engineering mode
Hi, I'm new to mercedes and I've just bought an early 2016 e250 cdi 212 model. I've been trying to access engineering mode and having no luck. Can get dealer mode. Tried the 3 buttons and nothing happens. I only want access to enable reverse camera. I'd like to fit an aftermarket camera. Can anyone help?
thanks
James
Old Aug 11, 2022 | 08:37 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
thanks
James
Are you talking about COMAND head unit Menu?
Good luck enabling aftermarket camera into stock gear...
​​​​​​FYI: Whatever you decide, resiste the urge to play with the "Factory Reset" option. This will soft-brick your unit, causing it to require professional SCN services.
Old Aug 12, 2022 | 05:38 AM
123jaye's Avatar
E class s212
yeah, I'm talking about the head unit. You can easily install an aftermarket camera, I just need access to the engineering mode to make the rear cam available. I tried the 3 buttons but it won't do anything
Old Aug 19, 2022 | 05:27 PM
anglil22's Avatar
2016 e350 W212
If you have a NTG 5 head unit, I don't believe you can access engineering mode. I have an e350 w212 with NTG 5.0 and there are no codes to access the engineering mode.
Old Sep 30, 2023 | 10:20 PM
orlandoblues's Avatar
a207 e550
​​​​​​I watched a video about the factory reset and then the combination to get into engineering mode. Are you sure it will soft break? How does this happen
