Sponsored by: CARiD
Oil Pressure - Liquid Moly 5W40 Leichtlauf High Tech
Old Sep 21, 2022 | 02:35 PM
  #51
kajtek1's Avatar
1922 Ford Model T / no OBD
Since you are done with different oils, how about putting diesel fuel into crankcase?
Others already did and it never showed low oil light.
You can skip first 2 minutes of advertising.
Old Sep 21, 2022 | 02:49 PM
  #52
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
(1) We Drained Our Engine's Oil and Replaced It With Diesel Fuel!!! How Far Will It Go?? - YouTube
Now, that's funny!
Old Sep 22, 2022 | 11:09 AM
  #53
S-Prihadi's Avatar
K1,
Now that we seen diesel fuel as engine oil, why dont you try Kerosene for us
Old Sep 22, 2022 | 04:44 PM
  #54
Well, since Kerosene is one cut in the column above diesel, and the diesel made it 37 laps before seizing the engine, I would suspect the Kero would make it 20 laps!
Old Sep 22, 2022 | 05:56 PM
  #55
kajtek1's Avatar
I think they did 20 on gas?
Old Sep 23, 2022 | 08:47 AM
  #56
Yes, the next cut would be white gas or lantern fuel, as you go up the column the lubricity decreases, so white gas would make it likely 10-15 laps and regular gas would be even less, but I'm unsure at that point if empty would do worse or better!
