Sponsored by: CARiD
Fluid leaking
Old Sep 12, 2022 | 01:45 PM
johnlk25's Avatar
2016 E400 4Matic
Fluid leaking
I have a 2016 E400, don’t drive it much, in fact it’s probably been a month since I’ve driven it. It stays parked in my garage. I woke up this morning and there is a huge puddle of clear water all around the front of the car that wasn’t there yesterday. I’ve determined that it’s windshield washer fluid. I’m just trying to figure out how all the sudden all my windshield washer fluid decided to leak out? It’s the strangest thing. Like I said, it hasn’t been driven in a month. Any ideas as to why it’s started leaking?
Old Sep 12, 2022 | 01:53 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
It's the standard washer pump seal that falls apart.
It's an easy 20mn fix through the left wheel well.
You washer fluid chemistry may not be compatible with the washer system. That how you get reminded to only use MB supplies!
I was afraid to read it was your clear brakes leaking 😳
Old Sep 12, 2022 | 11:12 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Whats the proper fluid, is the -20blue stuff ok? Ive always used that in my vehicles becauae it doesnt gunk up the sensors.
Old Sep 13, 2022 | 03:20 AM
Use the approved washer fluid,
I am afraid to use a standard washer fluid and cause a seal leak, destroy the sensor or tiny pump itself.
This basic system is designed to need repairs.
