Xentry/StarDiagnosis Airmatic Levels
Parked in garage, raised car using the button function, lowered back down, let settle. Car for whatever reason is showing rear driver side strut being -25 to -30 below others yet in reality it is not, if anything there's a little more wheel gap. I would think if a level sensor was bad I'd have an active or stored code and do not. This is making the level calibration impossible on the car (goal was to lower down to acceptable "Green" range as far as I could.
Any advice on what I can try different? Is there a way to recalibrate or read how level the surface is you're parked on? Garage is pretty flat.
biker349 (10-03-2022)
If there was any issues with the level sensor you would be getting codes for it. So, your car is leveled all around? You have no messages or codes? What exactly are looking for?
The following 2 users liked this post by MBENZTECH:
biker349 (10-03-2022),
pierrejoliat (10-02-2022)
Any tips to get left-rear to show closer to in range so I can evenly adjust and lower via Xentry? Not convinced sensor is bad but could be it.
edit: second pic is attempt to bend bracket which actually threw it out of range worse. Thanks in advance.
Received 4,374 Likes
It could be also the sensor value has drifted.
If you can swap between L and R of the rear, try it.
If you dont want to swap or mounting style are different between the 2, remove both from its mounting place and do full-UP and full-down and middle using your hand.
See if both sensors are showing the same range or not.
The following 2 users liked this post by S-Prihadi:
procrastiNATE (10-03-2022)
