Do not shift, service required. How do I start with this issue?
I can see this is not an easy job even with a car lift.
a spline helps gear alignment
The WIS procedure calls to remove drive shaft, cat-exhaust, engine support beam, lower the transmission and remove paneling covers... the engine is allowed stay put!
There may be ways to shortcut procedure by not removing the shaft and muffler by using slim wrenches (12mm, T20).
Now -> Reflecting on the failure mode of this module, I have decided for now to only prevent moisture intrusion through the leaky connector wires and to secure the vent pipe in place.
Later -> When the two rows of "solderless pins" start pilling up errors, I will have no other choice but to remove module to fix the internals. Until then my "no moisture" RTV fix should go a long way towards reliability.
I wonder what sealant material to use (silicone?) to close the module back to factory tight.
I fear that if I open my DSM module and use RTV to shut it may leak as soon as the RTV expires
Note that the DSM uses a vent tube that is marked in WIS to be replaced. This is that weird J-hook shape. Definitely avoid driving through any standing water to prevent filling up that module with liquid.
I really wonder why such a sealed module needs a breather vent ?!?
Perhaps to evaporate moisture from the harness connector such as what we see with headlights design? Not sealed, not water proofed but moisture managed.
have a few more inquiries, anyones know what circuit 61 and 50 do?
Also becareful with any scanner, more so icarsoft, which often still uses older generic terms MB uses, but probably no used anymore today or for newer cars
Here is about 61, I hope they are correct :
https://www.benzworld.org/threads/te...r-bcm.2995841/
https://mbworld.org/forums/e-class-w...ion-relay.html <<< see, older W211 circuit
These are the circuits designation for my engine/car M276 3.0 Turbo , M276.820
From ov00.01-p-1001-28daa, Abbreviations of signal and circuit designations for wiring diagrams. These are German DIN standard actually.
30 Battery voltage, positive (continuous positive)
30z Circuit 30, 1st input
30g Switched positive, fused
15 Not mentioned
15R Switched positive, in ignition position 1, 2 & 3
15R(1) Circuit 15R(1)
31 Return line to battery negative or ground, direct
50 Starter control (direct)
87 Input (Circuit 87)
87F Circuit 87 F (NAT control unit) *NAT in MB speak is transmission.
87M 87 Motor electronics
Have fun troubleshooting
Dang, so that is that small hook shape hose for. I thought it was tranny oil breather hose
at a glance
Even if water does not enter, road dust will be plenty and clogging it eventually.....
or eventually dust into inside ISM.
The big main one for engine block at starter solenoid from car body or ISM own wire harness's ground ?
Despite what everyone has said here, I was able to purchase the new ISM directly from the dealer myself and have it installed at a private shop. Only, I still had to get it coded at the dealer. This was done 2 days ago and the dealer gave it a clean bill of health. Fast forward to yesterday and the original shop had gone to pick it up for me to take delivery. They say after driving back with no problems, once the turned it off and started it back up it would not go into gear again. After letting the car idle for about 20 minutes it was able to shift normally. At cold start it was throwing all kinds of errors - CAN codes, low voltage, cannot communicate with shifter, etc. Once it idled the codes went away and it’s able to be driven like normal. I’ve been dealing with this issue for 1 month now. The tech is currently trying to figure out what is causing this new problem. The ISM is fixed as they are able to read data from it and shift the car with their scanner. Does ANYBODY know what could be causing this new issue? It’s looking like that’s what caused the ISM to fail to begin with.
