Sponsored by: CARiD
Workshop code
Old Oct 12, 2022 | 10:15 PM
HVF's Avatar
HVF
95 e320 Wagon, 98 s320 LWB
Workshop code
I changed the oil in my 2011 W212 and reset the service info. When I did that I noticed a workshop code. I have not seen workshop codes before .
The code is B3, then workshop code 3609. I don't understand the workshop codes and can't seem to find any listing for
them or how do I find the issue. I'm not getting any OBDII errors.
Thanks in advance for any help.
Harvey
Old Oct 13, 2022 | 12:05 PM
konigstiger's Avatar
'71 Pinto
Code generates vehicle-specific service sheet in MB WIS/MSS for tech. Cross reference services to attached sheet, mileage/time accrued.
Synthetic Motor Oil Replacement
Oil Filter Replacement
Cabin Dust/Combination Filter Replacement
Brake Fluid Exchange
All Fluid Level Checks & Corrections Are Dependent On Factory-Recommended Service Intervals For Your Vehicle's Year & Model.
Tire Inflation Check & Correction
Brake Component Inspection
Reset Maintenance Counter
File Type: pdf
Old Oct 13, 2022 | 03:06 PM
HVF's Avatar
HVF
Thank you for your help and the explanation. If I understand correctly you have listed the items that code refers to.
I have the WIS/MSS software so I guess somewhere in that software I can find the workshop code numbers and references. guess I will have to go hunting for it.
The service sheet in the PDF you sent does not reference the list of items needed, just a mileage and or time. when to do service. Or, maybe I'm confused (which certianly is a possibility).
Thank you again!
Harvey
Old Oct 13, 2022 | 03:39 PM
'71 Pinto
'Cross reference' services to attached sheet using 'your' mileage/time accrued.
Old Oct 23, 2022 | 01:25 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Don't make the services difficult to understand. From 2006 and up all Mercedes vehicles require either a "B" or "A" every year or 10k miles. The "A" service is pretty much an oil change and service reminder reset along with vehicle inspection. The "B" service is the same as the "A" but add cabin air filter replacement and brake fluid service/flush. Every 50k miles along with whatever service is due at the time, you will need spark plugs and engine air filter replacement. Transmission service for the 722.9 is due every 50k miles or 70k miles for the 7g+. Mercedes Benz does not have any specific service for differentials but I would do them every 50k miles. I forgot to add clean the front sunroof drains every "B" service.
Old Oct 24, 2024 | 02:42 AM
entersandman's Avatar
W205, X164
Hello Konigstiger!
Found your post as i came looking for what-in-the-world service codes are, when using the MSS section under Wis/Asra.
Did you generate this 11E.pdf sheet from your WIS? If so, could you please elaborate how to get it for another model?
I want to generate such a sheet for my cars - how can i do that?
Sorry if this is a noob question, but i've tried all options inside the WIS/EPC/MSS etc., but just keep going around in circles.
If you don't want to give your source, may you please generate one for my vehicles?
  1. 2007 GL450 4matic X164 engine 273
  2. 2019 C300 W205 engine 264
I do not possess Star or Xentry (yet) and thus not sure how to find ASSYST Plus codes directly from the vehicle.
Any help would be greatly appreciated.
Cheers !
Old Oct 24, 2024 | 08:23 AM
JettaRed's Avatar
Veteran: Army
Cheers !
Consider getting a BenzNinja Club membership. You'll get all the software you need, plus lifetime professional diagnostic support for all of your Mercedes.
