2011 E550 Battery/Alternator Issues
Sorry for rambling
01. From battery negative post to suspension well.
and
02. UNDER THE CAR. From body to starter motor body ( engine block )
You're one lucky owner in a million with a working charge circuit.... why replace the regulator then??
You can hardly get lucky changing parts to fix a problem you have not cornered. There are hundreds of reasons a German car is acting up to get worked on.
Scanning the car and fixing many bad GND are great ideas that will surely help.
2.5 year old battery in A/C climate with frequent need of jump start... it does sound like something's wrong.
-- The main battery is "young" (not super old)
-- The charge circuit supplies non-stop
>> check/clean the main batt chassis GND brass post! It's built to act as a funnel to send salty FL mist down it threads over a steel screw... is yours oxidized or clean??
While you're looking at the main GND connection the sleepless F-SAM is being rebooted. So drain while parked will be minimized.
Speaking of which, with FL daily rain showers and salty ocean mist, look for evidence of rain intrusion at front/rear fuse boxes, footwell carpets... any swampy module can help accelerate battery drainage while parked.
Pls don't forget to post your SCAN results. This step will save you both time + money.
2.5 years is young for a battery in most of the country, but living in Southwest Florida my whole life, I don't think I've ever had a battery make it 3 years. This Bosch one is still testing good for now though.
I was reading on other forum posts that 12.6 is where it's supposed to be while driving because of the smart charging system or whatever. I also noticed that the Volt meter in the engineering menu reads about half a volt lower then when I connect a multimeter to the battery.
If you see a .5 volt delta there must be a dirty connection somewhere - Clean things up for good measure while you're around there... free of charge is good!
.5v difference for a battery is a huge difference in charge level. You have to be careful how you compare measures: loaded vs. unloaded etc
Alternator output at or above 12.6V is perfectly good. Never anything below 12.3V with high Amps.
12.6V is when battery is fully charged up then voltage goes to float with minimal current close to 1A.
Xentry wont tell you the reason you need to jump the car/battery.
However, if there are many stored faults which looks whacky, a severe voltage drop below 9.6V system voltage can cause those weird STORED ( not CURRENT ) DTC.
Your under 3 years battery life is very much the same for Jakarta/Indonesia since my city is 365 days a year hot and some days raining, but we do not see any cooler than 25C at night.
Engine bay temperature kill battery fast in Jakarta, usually 2ish years and under 3 years too.
Some cars with battery located at the trunk, can live longer from cooler working temperature and more so because local owners of high $$ cars surely have a roofed garage, so car is shaded most of the time.
My friend walked me through doing a parasitic draw test on the car. After which, we believe that the amp is killing the battery. Going to drive the car for a week or so with that fuse pulled and see if it needs to be jumped.
Usually the vampire is sleepless-SAM but it may have new friends: Amplifiers do blow up ...
We look forward to your car working better.
I was thingking too electric, I thought you meant the AMP-erage is killing the battery....
60 milliamps is too little to FLAT your battery in even 48 hours, assuming it was at at-least 70% state of charge during last engine shutdown.
0.06 x 48 = 2.88 amps only
When you want to test for parasitic draw, first is to make sure the car can go to a TRUE sleep mode. This can take up to 6 hours after car is driven but when car is parked at home and hood already open since last engine kill,
TRUE sleep mode can happen very fast, sometimes under 30 minutes after you open and close the door to take something.
To know if TRUE sleep mode has occur or not is simple. Use a test light or a voltmeter and read IG 1 post for 12V, if there is still 12V, TRUE sleep mode has not yet occur.
Relay K2 open/un-lached is what shutdown the IG1 and MRG2 or MG2 terminal/post.
Above : My car is Right Hand Drive, so dont get confused. LOL
My car has Start Stop B03 option, being a 2014 facelift. Later model or at least my facelift, pyrofuse is at battery POSITIVE terminal and not at F32. Below is F32 pre-fuse block.
Correction for yellow box above : the waiting period to SLEEP MODE, can be up to 6 hours if car just been driven.
Now, in theory : a TRUE sleep mode will happen if the computers observe that there is no more activity among the modules and is a good time to SLEEP.
If any module/s still not finish with its/their business/task or in a faulty mode which it/they can not sleep or do deep-standy by, TRUE sleep mode may not happen.
So easiest for now is to make sure TRUE sleep can happen.
Have fun troubleshooting.........
Still I would think that video I linked to test your battery should also be done.
So far so good on that fuse being pulled though.
- 12.8 V when new and recently charged and disconnected from the cars --> Unloaded. Of course, use a voltmeter since it is disconnected.
- 12.x V when connected with the car and the computers awake and draining a bit. --> Loaded
- 14.x V when regulator at its best --> Do not touch the charging system, It cannot get any better.
- 12.6 V when the regulator nears its end life. Anything below and you will be jumping the car more often, and likely burn something at some point (we all make mistakes). Time to look at the alternator/regulator components.
I do have keyless go and always use the sensor on the door handle to lock the car.
The maximum voltage for any high-quality automotive battery in the 12V range is 12.8V when new, charged, and w/o any electric load. Those batteries are usually 6 cells of 2.1V --> 12.6V +/- error.
It is true the W212 platform has a smart charging system that will try not to overcharge the battery once it is charged. That is, 12.6V only if there is no load in the vehicle, which means the car is basically OFF. If you drive with AC on, and anything else on: radio, lights, accessories it will be above 12.6V for quite a while after starting the engine. If I recall correctly, the cluster voltage must be activated when the car is OFF, then start the engine. Yours have to be higher than 12.6V for at least a few minutes.
The ALT always supplies 100% of the car power during drive time. Battery is either actively charging or idle standing-by, never contributing power in normal driving outside of ECO cycle.
