Sponsored by: CARiD
2008 mercedes e350
Old Nov 12, 2022 | 07:34 AM
biker349's Avatar
cl600
Question 2008 mercedes e350
my clock i one hour fast. how do i bring the clock back one hour? i read through the manual and could not find any info. tried resetting the clock through the dash board settings and was unable to get it to work.
any advice and input is greatly appreciated.
thank you
Old Nov 12, 2022 | 07:56 AM
Raj1471's Avatar
2011 Mercedes E350 4Matic Wagon
Here you go....
Old Nov 13, 2022 | 08:28 AM
biker349's Avatar
cl600
thank you very much for the info. i will try this today.
Old Nov 15, 2022 | 08:37 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
If you're in the US, the car uses the old daylight savings dates which were changed, I reset my clocks in both cars for the two weeks that they lengthened it to and it just goes back to the DST after driving a couple times, you'll have that in the spring too.
Old Nov 15, 2022 | 10:00 AM
DFWdude's Avatar
2016 E350 Sport
...except in the facelift models, the clock seems to get its calibration signal directly via the GPS signal used for navigation. This is updated in "real time" regardless of DST or standard time, so the clock springs ahead or falls back whenever GPS displays the current time.
Don't know if I stated it correctly, but at least I've not had to manually adjust the time...
Old Nov 15, 2022 | 10:31 AM
MeltdownSpectre's Avatar
2013 E250 CGI (M271 EVO)
This is correct.
I remember trying to diagnose an electrical issue and I had disconnected the battery while the car was in underground parking, and after reconnecting it, the date/time on the car were reset to 1 Jan 2017 00:00. Couldn't figure out how to set it manually through COMAND.
I guess there was no GPS signal 2 levels below because once I drove out of underground parking, I heard a whining noise and saw the clock between the AC vents automatically setting itself to the right time.
Old Nov 15, 2022 | 02:58 PM
Nice! I had to learn to put up with it being wrong for weeks twice a year.
Old Nov 16, 2022 | 06:20 PM
biker349's Avatar
cl600
i tried resetting my clock as per you tube instructions. after playng with it for about an hour i could not get it to start the next morning. the battery was dead. i got it jump
started and ran it for about an hour. brought it discount auto and had them test it. the alternator showed good voltage and the battery checked out good. they suggested putting a trickle charge on the battery over night and then bringing it back for further diagnosis they felt that the trickle charge would correct the problem.
i will see what the diagnosis is tomorrow. hopefully the battery and alternator will check out good and i won't have to buy a new battery.
any input, or suggestions would be greatly appreciated.
thank you, biker
Old Nov 17, 2022 | 10:14 AM
konigstiger's Avatar
'71 Pinto
211 should be posting here: https://mbworld.org/forums/e-class-w211-20/ attached bulletin may be applicable.
File Type: pdf
Old Nov 17, 2022 | 06:15 PM
biker349's Avatar
cl600
put a float charge on battery for 24 hours. tried to start car. no good. battery was dead. did a jump start and took car to discount auto. battery was dead. bought a new battery and they installed. now all is good and car starts. cost $250 and they installed it.
thanks for all your feedback.
the best, harv
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
