Sponsored by: CARiD
A/C button not working, always on
Old Nov 14, 2022 | 09:55 PM
ath20's Avatar
1987 260E & 2013 E350 Sport
Unless I'm running the front defroster, my a/c compressor is always running. Pressing the a/c button has no effect. The only time it shuts off is when I put on the front defrost. From what I see, it should shut off when pressing the a/c button.
Any advice? Thanks. 2013 E350
Old Nov 15, 2022 | 07:22 PM
ath20's Avatar
Any ideas?
Old Nov 15, 2022 | 07:55 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
mine turns on and off with the a/c button unless you have defrost selected in manual mode
Old Nov 15, 2022 | 09:04 PM
ath20's Avatar
That the thing, mine never turns off unless it is in defrost mode. Is there a way to reset it or something?
Old Nov 16, 2022 | 08:05 AM
So, if you are using manual mode, where you have icons in the display denoting where you have directed the air, if the windshield or defrost symbol is showing the A/c is on, try switching to Auto then the A/c light should come on, then use it and it should go off.
Or set the manual mode to vents or floor only and it should be off. you can try pulling the negative battery cable for a system reset for 10-15 minutes.
Old Nov 16, 2022 | 07:00 PM
ath20's Avatar
I tried that, and the A/C button still doesn't work. It's like it's stuck being on.
Old Nov 17, 2022 | 09:10 AM
That's so weird, wonder if somebody spilled something on the switches and their stuck? I know that's happened a few times, try the battery disconnect to reset systems, but it sounds like the switch? does it have the same tactile feel as the other switches?
Old Nov 17, 2022 | 01:46 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
does the red light on the a/c button toggle when you push it?
the AC will stay on if the temp setting on either side is lower than the car's interior temperature... so, kick the temp up to like 80, and it should shut off.
Old Nov 17, 2022 | 01:52 PM
Maybe in the facelift, or on Auto, neither of mine does that
Old Nov 17, 2022 | 05:28 PM
ath20's Avatar
Button works just like all the rest of them, except the compressor keeps running. I do wonder if maybe someone spilled a drink, but everything else functions as it should.
Red light is on at all times unless the defrost is on. Button functions fine (except the obvious) I tried cranking up the heat as well, nothing.
Old Nov 18, 2022 | 10:02 AM
konigstiger's Avatar
'71 Pinto
Have someone erase all stored codes and do a quick test using Xentry (MB diagnostics) AC CU ‘may’ need to be re-initialied or worst case replaced requiring Xentry.
File Type: pdf
Old Nov 18, 2022 | 05:08 PM
jjpaget's Avatar
W212
I have the same problem. My AC light has been on for YEARS. Nothing I have done turns it off.
Old Nov 18, 2022 | 05:29 PM
if the AC light doesn't toggle with the button, its a good chance that the button is NOT working.
Old Nov 19, 2022 | 04:46 PM
ath20's Avatar
So I need one of those Star Dianostic computer things? I'm debating buying one. Lol.
Yeah... LOL. I guess I'd rather have it on all the time, then to have no a/c.
Old Nov 23, 2022 | 04:25 PM
Lyupen's Avatar
2013 Mercedes Benz E350 4matic
Last edited by Lyupen; Nov 23, 2022 at 07:57 PM. Reason: I posted in wrong section
Old Aug 3, 2023 | 01:27 PM
spcds1529's Avatar
2016 E-350/ 2000 GMC Sierra
https://www.youtube.com/watch?v=xeVq...rcedes-BenzUSA
Did you ever get this issue fixed? Mine is doing the same thing. I think water was spilled on it. My concern is that I'm wearing out the A/C compressor prematurely. I looked and changing out the control panel does not look that complicated.
Old Aug 4, 2023 | 12:12 PM
ath20's Avatar
Nope. Still don’t know why it’s doing it. The only way to turn it off is to turn the whole system off, or turn on the defroster.
