will these wheels fit my E class?
will these 18inch wheels off a CLA fit and be ok?
https://www.facebook.com/marketplace/item/493773702842696/?hoisted=false&ref=browse_tab&referral_code=marketplace_general&referral_story_type=general&tracking=%7B%22qid%22%3A%22-4957152568349667404%22%2C%22mf_story_key%22%3A%22991670763709793569%22%2C%22commerce_rank_obj%22%3A%22%7B%5C%22target_id%5C%22%3A991670763709793569%2C%5C%22target_type%5C%22%3A6%2C%5C%22primary_position%5C%22%3A1%2C%5C%22ranking_signature%5C%22%3A6332676033795325952%2C%5C%22commerce_channel%5C%22%3A501%2C%5C%22value%5C%22%3A0.00053116989975704%2C%5C%22upsell_type%5C%22%3A3523%2C%5C%22candidate_retrieval_source_map%5C%22%3A%7B%5C%225781283711986675%5C%22%3A3002%2C%5C%225761230110619864%5C%22%3A3001%2C%5C%228388036947934385%5C%22%3A701%2C%5C%225877317632361922%5C%22%3A701%2C%5C%226245299788853510%5C%22%3A701%2C%5C%227901795589895839%5C%22%3A701%7D%2C%5C%22grouping_info%5C%22%3Anull%7D%22%2C%22lightning_feed_qid%22%3A%22-4957153392796857298%22%2C%22lightning_feed_ranking_signature%22%3A%226332676033795325952%22%2C%22ftmd_400706%22%3A%22111112l%22%7D
Wheels fit based on pictures and MB model is difficult since the same front/appearance is made is different configurations.
if they are original, the part number is at the back: part number, width, offset and diameter are important. Then compare to ranges for each on S212.
diameter is obvious from the tires in the picture: 18"
width can be guessed based on the tire width: J7.5 for such tire..
Offset: impossible from this picture. Wrong offset and the the tire will rub inside, or outside
The link above may help with the specs with that set
It seems like 18" x J7.5 x ET52
At the end of the day, if you’re using 18 wheels on these cars, then its probably easier to just consider the rims as disposable. Go on cars.com and look up the 212’s for sale. Look for the ones with 18 inch wheels and read the carfax entries on them. Endless tire and wheel repairs almost immediately. If the $850 “AMG” wheel can’t survive a pothole, then why spend the money for the badge? I am about to replace all 4 for the price of one.
funny, in that picture with the damaged rim in the back - looks exactly like a promo video MB did to illustrate why you should only buy their wheels! They ran a car over a speed bump, one with aftermarket and one with MB wheels. Aftermarket lost a piece of the lip just like in that picture. The MB wheel looked like it didn’t even flinch, no damage no nothing. Except I, and willing to bet many others here, would most definitely argue that it probably sounds like you’re driving a helicopter now in that test car, meaning a trip (and expense) to get it fixed, in hopes they actually can get it fixed back to new. Me? After 5 years of trying, have my doubts.. so, instead of $150-$200 for a repair bill that may or not work, I’d rather just spend it on another wheel that was brand new and not have to worry about if it was fixed correctly or not…
Once we get new parts, we tend to blame the older parts for the failures, like NEW means perfect, and then circled around frustrated with issues.
On my original rim, AMG by Ronald which is Czech-made
, the NUT is not the same as what I will need on my BBS CH-R aftermarket wheel.To un-trained eye, one may miss this BOLT detail, becareful.
The cone or taper shape and angle is different on BBS CH-R which I believe is a common aftermarket wheel bolt taper specification.
My OE Mercedes bolt is like this : kinda rounded taper
My BBS CH-R bolt is like this, 60 degrees taper.
edit: also to be noted, Mercedes uses hub centric wheels, *not* bolt centric. so the 'hole' in the middle of the wheel is what centers it, and that has to be precise. many aftermarket wheels aren't very good in this respect.
Superb dimensional accuracy with soft nice taper for "entry" of wheel hub protrusion, it is aluminum ring and a clip
