Sponsored by: CARiD
Car wont move in drive, but can reverse
Old Jan 26, 2023 | 05:18 PM
Azhy's Avatar
2012 E550 4MATIC
(resolved)
I have a 2012 E550. My sister was driving my car and broke down. She had called me and said she heard a loud hiss then a few minutes later the car just stopped moving. Luckily she was in a parking lot. When I went to go check it out I thought my rear brakes had locked up (still might be possible?), but I noticed I was able to drive the car in reverse. It was unable to be pushed in neutral either. In Drive I slowly accelerated and for a sec something felt like it slipped and i moved forward just a little bit before it locked up again. I have an iCarsoft and checked for fault codes in the transmission and nothing came up. The gears shift without a problem and even the paddle shifting worked fine. Based off some research I did I am assuming the hiss was a fluid tube bursting and leaking out transmission fluid. I'm getting the car towed to my house to work on it. I would like more opinions on what you guys think is going on with the car. Thanks.
Update: bolt for rear right caliper had fallen off for some reason and caliper got stuck to wheel.
Old Jan 26, 2023 | 09:45 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Get it home and inspect. No one can tell you anything unless you can give us some more info.
Old Jan 26, 2023 | 10:19 PM
Azhy's Avatar
2012 E550 4MATIC
I have. Updated my original text. Issue has been resolved.
Old Jan 27, 2023 | 03:53 AM
BenzV12's Avatar
W212 FL
Nice to see you fixed it , and was an easy fix
Happy Driving
Old Jan 27, 2023 | 04:17 PM
Azhy's Avatar
2012 E550 4MATIC
Happy Driving
Yes thank you. such a relief I thought I had to deal with the transmission.
