2011 E350 RWD engine mounts
anyone have experience with a 2011 E350 RWD model?
Repair manual says to jack the engine and should be enough room to remove the mounts,
But that's not the case from my experience and the local MB shop next to me, the exhaust has to come out to get the mounts out.
There might be an easier way to get them out.
Also, you'll need the 16mm offset tool for the nut on top of the mount, very hard to get at.
John
I decided on the steering rack because driver side was tight and I could only get the tool on it from below. With rack moved it was much easier.
The passenger side top bolt came out from top side. I wasted 30min and was frustrated with getting the top bolt started on new mount passenger side. It just wouldn’t catch so a touch of antiseeze and getting a little pissed helped it go in.
torquing the top bolts was a pia too. Overall though your advice was priceless and job was easier than expected.
trans mount was a piece of cake.
