Sponsored by: CARiD
Coolant leak
Old Feb 3, 2023 | 11:44 PM
lgnd64's Avatar
E63s
Coolant leak
Hello
i have a coolant leak from the radiator. Do you think it might be the radiator or the hose? I attached the video of the leak
https://youtube.com/shorts/pH0heq9idQU?feature=share
Old Feb 4, 2023 | 04:50 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
RED??
Originally Posted by lgnd64
Hello
What year model is your E63 engine?
Is that RED coolant really compatible with MB own YLW/BLU mix?
It looks like the hot hose inlet is what leaking super bad...
Old Feb 4, 2023 | 07:36 AM
lgnd64's Avatar
E63s
i have a 2015
dealer put in pink.
does the radiator need to be replaced or just the hose ?
Old Feb 5, 2023 | 08:39 AM
S-Prihadi's Avatar
You best ask at AMG forum. https://mbworld.org/forums/w212-amg-146/ because they are more familiar with your engine.
Your engine I think is M157
Such a leak need to be investigated/inspected by a techy familiar with M157 engine if you are not a decently good DIY
Many components can leak coolant.
Here is an example by knowledgeable DIY
Also when showing someone a problem point inside an engine bay,
the video must start at wide angle, so people can see which region of the engine you meant, when the video goes to close up mode.
