Seat control hazard panel
Received 4,446 Likes
'71 Pinto
Hazard panel are you referencing UCP if so, check f40 (5A) @ interior fuse panel.
Received 3,651 Likes
MY'14 W212 M276 3.5NA @60kMi
Hazards are switched by SAM...
1-- The step after fuse check is software related.
2--- Scan your vehicle will let you understand if a condition is preventing normal SAM operation to power your blinkers.
3-- car has sufficient on-board power to run reliably.
'71 Pinto
Check UCP connections & associated CAN connector if fine may be UCP should throw code.
