Sponsored by: CARiD
Key FOB
Old Feb 7, 2023 | 12:23 PM
rwolak's Avatar
2003 CLK500, 2008 e350
Key FOB
2012 E350. One of my two key fobs will not start the car. It locks/unlocks doors fine, opens the trunk fine. However, it won't start the car. No starter clicks, just dead silence. I have checked the infrared light is functioning. Have changed batteries a few times. Still dead silence. I do have a second remote that works fine.
Any ideas or suggestions?
Old Feb 7, 2023 | 01:09 PM
slovcan's Avatar
2011 E350 CDI 4Matic, Rover 75, Chevy K2500, 2 motorcycles
Probably a dealer visit to reprogram the immobilizer chip in it. Or whatever is in there that identifies it to the car.
Old Feb 7, 2023 | 01:10 PM
cetialpha5's Avatar
What's the voltage of the batteries when you change them? Do you have a volt meter? Lots of dead batteries out there sold as new but they've been on the shelf too long. When you put it into the ignition does it turn all the way? You could take out the battery and try some electrical contact cleaner if you've checked the battery voltage and it's good. Or get a tile/apple airtag for your other good key so you don't lose that one. A new key is rather pricey.
Old Feb 7, 2023 | 02:12 PM
rwolak's Avatar
Voltage on all batteries used was 3+ volts. Even did the electrical contact cleaner, still no change. Strange thing is I used the car yesterday, no problems. Parked it overnight and the on fob wouldn't start it. Everyother function on the fob worked. Gotta be something in the fob since my other one works fine.
Old Feb 7, 2023 | 02:15 PM
cetialpha5's Avatar
Then it just sounds like a bad fob. It's usually either a bad fob or a problem with the electronic ignition. It's worse if it's the electronic ignition. Do you have keyless go?
Old Feb 7, 2023 | 03:33 PM
rwolak's Avatar
No keyless go. Doubt if it’s a bad ignition.
My other key works fine. Can these keys loose programming?
Old Feb 7, 2023 | 05:19 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
These keys are not re-programmable, i.e. if it lost the programming you can consider it gone.
However, these keys use induction, i.e. do not require battery to communicate with the ignition. You can take the batteries from your working key fob and it will still start your car. Batteries are opening the doors, and communicate with keyless go.
Can the be repaired? Not an expert on it. Did your keyfob fall on the ground, or got wet. If the inductive coil inside got damage, the key is a paper weight. In the meantime, careful with the working key.
Old Feb 7, 2023 | 05:20 PM
konigstiger's Avatar
'71 Pinto
Yes. Also, internal board can fail.
Old Feb 7, 2023 | 05:54 PM
rwolak's Avatar
Thanks for all the replies. A friend, who is a locksmith, has programmed many blank MB fobs. He’s going to take a look and see if there’s something I’m missing. Worse that can happen is I get a new fob.
Old Feb 12, 2023 | 04:02 PM
M_patton's Avatar
W212 E550 4 matic
ESL
I have a c300 that had same problem
it was the ESL
I am positive it’s a common issue with that W204
here is a link to issue
https://www.benzworld.org/threads/co...thers.3046041/
Old Feb 13, 2023 | 09:10 AM
benidB's Avatar
W212
another user just posted a similar problem
https://mbworld.org/forums/e-class-w...nk-no-aux.html
if no light comes up in the dash when you turn the keys, its likely the esl is broken. Check the link, I posted some other threads there that you can read..
Old Feb 13, 2023 | 11:43 AM
'71 Pinto
Originally Posted by M_patton
I have a c300 that had same problem it was the ESL
Only key malfunctions.
