Sponsored by: CARiD
Coolant question
Old Feb 26, 2023 | 07:52 AM
Shafayet Nabi's Avatar
E250
Coolant question
Hi guys,
Can i use 325.0 instead of 325.6 ?
Old Feb 26, 2023 | 09:21 AM
KlausPA's Avatar
E350 Wagon
Yes, that's what I have in both of my Mercs. One has 160k miles and the other one approaching 100k miles.
Old Feb 26, 2023 | 09:26 AM
E250
Thank you
Old Feb 26, 2023 | 10:48 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
do not mix those two.
325.0 was used on cars up to manufacturing date of April 2014. 325.6 was used on everything newer.
Mercedes says you can use 325.6 on older cars (after thorough flushing), but you can NOT use 325.0 in newer ones. Caveat Emptor.
Note 326.0 and 326.6 are ready mix, already diluted 50-50, while the 325.X fluids are concentrates that must be mixed 50-50 with water.
325.0/326.0 are blue-green, this fluid is known generically as G48
325.6/326.6 are pink. This fluid is equivalent to G40...
note, you can NOT rely on the color across different brands of coolant.
the big difference is, 325.6 / G40 does not have any Borate or 2-Ethylhexanoic Acid in it. 325.0 does.
here's all the coolant related Mercedes specifications,
https://operatingfluids.mercedes-ben...ory/coolant/en
this is which spec to use for what engines...
https://operatingfluids.mercedes-ben...sheet/320.1/en
here's a list of 325.0 coolants
https://operatingfluids.mercedes-ben...sheet/325.0/en
here's a list of 325.6 coolants
https://operatingfluids.mercedes-ben...sheet/325.6/en
usually available in the USA is ...
Zerex G 48 - 325.0
Zerex G 40 - 325.6
DO NOT confuse these with the very common Zerex G05 in the gold jug, this meets a MUCH older Mercedes spec used in the 1980s/90s. I used this in my W124's and my 80s/90s Volvos as it met their spec perfectly.
Old Feb 27, 2023 | 10:21 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
I found a note some time ago, that those coolants are mixable, but since they come in different colors, I still would do good flush.
Get 5-6 gallons of distillate water , drain, refill, drive something, repeat till water comes clean and then refill with proper coolant mix.
Old Feb 27, 2023 | 10:27 AM
E250
Actually I'm not mixing. I'm not getting 325.5 that's why i was asking can i use 325.0?
Old Feb 27, 2023 | 12:37 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
what year is your car? LCG's comments are correct.
Old Feb 27, 2023 | 12:47 PM
E250
(2015)E250 2.L turbo
Old Feb 27, 2023 | 01:14 PM
DFWdude's Avatar
2016 E350 Sport
So, no 325.0 on your 2015...
Old Feb 27, 2023 | 01:18 PM
E250
Thanks for the clarification
