w212 high gears low speed.
Hey everyone,
I've a w212 e220 cdi with 560k KMs.
It it having a issue, you give it gas and it doesn't go beyond 2.2k RPMS and changes the gear to 4th or 5th immediately. When you put it in manual, the RPM goes normally until max RPM allowed. Only when its in D it does that.
No check engine, no codes on the computer, can anyone help please.
It is the e220 with 5 gear gearbox.
Received 3,448 Likes
MY'14 W212 M276 3.5NA @60kMi
what could be wrong...
Diesel in limp mode with half million KM.
"No code"....
Shifts well manually.
-- What scanner is it you're using ??
-- Look at TCU PIDS for obvious data discrepancies.
-- You said "no code"... not a bad shaft rpm sensor then!
"No code"....
