Sponsored by: CARiD
Temperature gauge/cooling fan problems
Old Mar 16, 2023 | 12:51 PM
Garrath's Avatar
2010 Mercedes E 350
2010 E350 W212 and the temperature guage won't rise at all and the cooling fans come on. If I switch off the engine and switch back on again the temp guage goes up and the fans go off. It's not every time I drive it, just every now and again.
Old Mar 16, 2023 | 04:26 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
unreliable temp signal...
I don't suppose you have a scanner to read the temp sensor data, right? ECU would readily help you with a fault code! 🤞
Then blindly replace cheap sensor with a genuine OEM part. Assume yours may be feeding coolant into harness, inspect.
