Sponsored by: CARiD
Engine Mounts/Transmission mounts
Old Mar 25, 2023 | 11:52 AM
Jameskdermody's Avatar
1993 Mercedes 190E 2.6, 2011 Mercedes E350
New to the forum and I am not sure it this has been posted or if someone can direct me or help me out. Looking for WIS on how to do motor mounts and the transmission mount. 2011 w212 is the model engine 278 I believe
Thanks, James
Old Mar 25, 2023 | 06:05 PM
cetialpha5's Avatar
You're trying to find it in the WIS or you're trying get the WIS? You can get a knock off copy of the WIS on eBay for just a few dollars. Just search for Mercedes WIS. It also comes with EPC. Transmission mount is pretty simple, a quick 20 minute job, motor mounts are way more involved. Also lots of threads cover this.
https://www.ebay.com/itm/185421674259
Old Mar 27, 2023 | 12:55 PM
AllPhonesAretap's Avatar
2013 W212 E350 RWD
Thanks, James
Not to be rude but there's no way you even looked, not at all. Had you used the search function you'd fine this subject has been covered ad-nauseam
Old Mar 27, 2023 | 03:08 PM
I dont own WIS nor have I ever used it…I have seen people on here attach the images from WIS when people had asked for help or guidance with repairs and they simply post the links with the pictures and its step by step process. I was hoping to land those with the torque settings because I dont own WIS but the gentleman above you provided me with a link and I purchased it but thanks for the help much appreciated…if your not going to provide a answer why even reply?
Old Mar 27, 2023 | 03:48 PM
2013 W212 E350 RWD
Like I said I wasn't trying to be rude, just direct. I said what I said because literally every week someone comes and posts about engine mounts, pretty much exactly what you're asking, then they disappear and never post again.
Old Mar 27, 2023 | 06:29 PM
understandable I unfortunately brought my car to dealer and they wanna bend me over backwards on alot of repairs that need to be done and I want to DIY things I know I can do but I want accurate correct info on what I am doing dont wanna go off youtube videos
Old Mar 27, 2023 | 06:37 PM
cetialpha5's Avatar
There's several threads on this forum about motor mounts. You just need to use the search feature. Use the search function to just search this forum and if you search for motor mounts, you'll get tons of threads. About the only thing you might need done at the dealer is the firmware upgrade if your bluetooth/sirius is skipping. Otherwise pretty much everything else you can either DIY or take to an indy mechanic.
https://mbworld.org/forums/e-class-w...-question.html
Old Mar 28, 2023 | 01:45 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
Old Mar 28, 2023 | 02:24 PM
See attachments.
thank you both of you for the information..much appreciated!
