Rear Camber Adjustment Kits
THANKS!
So those with the k-mac how much more tire life did you get?
Are they wearing more evenly now?
Does it handle better in the rain since more tread gripping road.
I sold my W212 about 3 years later and the tires still looked in good shape. By eliminating the rear camber, you're going to sacrifice cornering performance at high speeds - that's why track cars run negative camber.
For everyday driving though, you're not going to notice the difference The trade-off is well worth it. (unless you track your car or drive like a speed demon)
Hey guys, sorry to revive the thread... i'm going to install the kmac bushings on front and rear for camber adjustment. Is the install easy? Do I need to take anything apart prior to accessing the bushings? Where are the bushings located? Anything helps... trying to plan it out, thanks.
2013 ML350 Bluetec
I only did the rear on my '13 E350 a few years ago. I remember only a couple bloody knuckles, penetrating oil, and close study of the included instructions. It isn't too hard; the second side will go faster than the first. No special tools that aren't included in the kit are needed. Jackstands work, a lift would make it way easier.
#32
SPONSOR
The front and rear Camber bushings also replace the highest wearing.
See Spoiler - have attached front and rear instruction sheets.
Latest upgrade is front now also no special tools or need for time consuming arm removal to fit.
Now fit on vehicle / bush extraction insertion tools included!
Easily access precise single wrench adjustment ULTIMATE - Direct on alignment rack (UNDER LOAD) !
Kevin
Spoiler
#33
Thanks @rapidoxidation , taking notes.
@K-Mac Thanks for additional instructions. Did I purchase the correct ones for my 2015 CLS 400? https://k-mac-camber-kits.com/produc...incl-amg-w204/, https://k-mac-camber-kits.com/produc...-front-camber/
#34
SPONSOR
Front #502916-1i (Camber Only)
NOTE Front Camber (& also Caster adjustment) is #502916K.
Rear (Camber & Extra Toe adjustment) #502126K
Kevin
si_el_es_cls (12-05-2023)
