Where to buy H&R springs
I've got a 2012 E550 4Matic Sedan (no air bags) and looking to get some H&R lowering springs, but the usual places I look have may different fitments and don't seem to be straight forward on what they fit. Does someone have a part number or can you point me to a reputable Mercedes tuning site that would have these? Thanks.
So, just any w212 E class sedan has the same part number for the Eibach kit, at least for the E500, which is the 550 in the states. Is the coupe the same as well?
I just want the 1" lower that the H&R give, from what I've read. All others seem to go lower, which would be too low for the wheels I have.
Received 4,449 Likes
When using lowered spring, make sure the damper maximum bottom out is calculated too. These 2 must match.
Example, Bilstein B6 is a sportier version of B4 which is standard damper.
B8 is the shorter version of B6, which is made for shortened spring.
https://workshop.bilstein.com/en/sho...ison-b4-b6-b8/
What you do not want is your damper main body becomes the BUMP STOP.
