Broken Fuel filler flap
2011 E350 wagon
New MB owner! I bought the 2011 E350 Wagon, but with a broken fuel filler flap. Just the exterior panel was pulled off - the flapper still works fine. Looks like the previous owner tried to glue it back and that did not work. Lots of residual glue all over the back of the exterior panel. Is this common? Ideas to fix it? thanks
Received 4,446 Likes
'71 Pinto
If mount and panel in question can be properly cleaned remount using Gorilla Glue. If not, clean mount as best you can and replace panel used will need to be painted unless you find match. 213 same procedure to remove/install panel.
pierrejoliat (04-16-2023)
2011 E350 wagon
Thx -Out of Control- tab is broken so I'll try the gorilla glue fix
https://youtu.be/u20v-LjmSq4
The following 2 users liked this post by Quint22:
CaliBenzDriver (04-16-2023),
