Sponsored by: CARiD
Emergency: Service Required, Do not shift gears visit Dealer
Old Apr 26, 2023 | 09:46 PM
jayalaba's Avatar
2006 E350
2011 E350. Not starting. Got the message in RED on the display. What went wrong. Stopped overnight and this morning not starting. Battery is good. Charged and Checked.
Old Apr 26, 2023 | 11:00 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Its your gear selector on the transmission (ISM) playing its loose connection drama.
Get it worked on to resume driving. Many sources available .
Scan the car to confirm surrounding partners faults then deal with issues.
Old Apr 26, 2023 | 11:14 PM
jayalaba's Avatar
2006 E350
CalifBenzdriver, I am not able to start the car at all. nothing happened.
Old Apr 26, 2023 | 11:22 PM
Yes, that is was to be expected. Do not ignore Benz warnings: each MB system has a prime day and a trained team to work it.
Old May 14, 2023 | 03:33 PM
Simon350S's Avatar
ML420 CDI
I’m fighting the same problem with my ML.
have you got yours sorted? Looking to join BenzNinja in the hope he can help confirm the issue and programme a replacement module.
I’ve picked up a good used DSM Module, opened up my old and this new module and swapped the circuit boards in the hope it would fix the issue without the need for coding, but the fault remains the same…..! 🤬
Old May 14, 2023 | 05:36 PM
AllPhonesAretap's Avatar
2013 W212 E350 RWD
There's a small youtube channel called Mercedes benz Specialist, he has a lot of videos where he talks about High level Mercedes repairs. I would try reaching out to him
Old May 15, 2023 | 02:18 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Check codes applies regardless if that is E or ML
