Camshaft and solenoid sensor replacement
Dealer is correct, and FCP Euro (unfortunately) do not have them. I directly notice that to FCP Euro via email/you tube since another MBWorld forum member highlighted so in a separate thread
here is what you want
https://www.ebay.com/itm/37459464874...hoCDHwQAvD_BwE
I also found this Youtube video below from a popular channel which was posted less than 2 weeks ago. He bought a 2014 S550 and it had the same problem with the oil leaking from the position sensors and solenoids into the wiring harness. His car was already throwing up codes and a check engine light because the oil leak had done enough damage. He goes through the diagnostic and repair process. I learned some things from watching that. (There are a couple of other parts to this video on his channel related to his S550 if you want to check it out).
The following 3 users liked this post by jumpman726:
2012 E550 sedan 2019 E63 Wagon
Hey guys, does the coolant cooler need to be removed on a W212 2012 E550 sedan in order to replace the camshaft position sensors and magnets?
I contacted an indi shop for an estimate and they included the cost for a coolant flush because they said the coolant cooler needed to be removed for the job.
Is that true?
By the way, I contacted a dealer for an estimate and they wanted $1,900 + tax to replace all 4 cam position sensors and all 4 cam solenoid magnets.
Is that true?
Run from that dealership, at the speed of light. It took me less than a hour to get it done, and I suck at working on cars.
The following 2 users liked this post by S. Madman:
juanmor40 (06-09-2023),
pierrejoliat (06-10-2023)
The hardest part was getting the bolts to come loose because they had been baked in for the last 10 years, but other than that it was pretty easy. The only thing is I don't have a torque wrench so I couldn't torque the bolts to spec. I tightened them to the German spec.... "Good-and-tight." Haha.
I ordered the solenoids from Amazon for $33 a piece and they are arriving tomorrow. They are supposed to be OEM Mercedes parts. My solenoids have a little bit of oil seeping in, but they haven't reached the male connector wiring yet. The position sensors were definitely in much worse shape.
Today when I drove the car after installing the position sensors I immediately noticed an improvement. The engine runs much smoother and it even feels quicker when accelerating. It feels great doing the job yourself and saving money at the same time.
Jaybird123 (06-11-2023)
