E63 Air Suspension Malfunction
Hi, My W212 E63 AMG has a weird fault - Dash is reporting "Air suspension - Malfunction", although when i use the AMG buttons to adjust suspension, all seems good. Ride height is normal also.
Have checked fuses, if I turn vehicle off and on, the message has gone.
Thinking I might needs an OBD2 reader....any recommendations?
Thanks World!
Thanks World!
Received 2,128 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Connect icarsoft and read codes/dtc
check out the links in the sticky in the more specific w212 amg forum
https://mbworld.org/forums/w212-amg/...-w212-amg.html
pierrejoliat (05-01-2023)
Thanks World!
Thanks World!
The following 2 users liked this post by Arrie:
j4jack (05-01-2023),
pierrejoliat (05-16-2023)
W212 Airmatic fault
I have had the same issue. I used an Autel MaxiSys and got these codes. Now that I have the codes I have no clue what to do .
Ci55664 : Compressed air sensor pressure has a malfunction. There is an implausible signal.
C156C00 : System "compresses air distribution" is leaky
My car runs just fine...except my airmatic does not work once I get the malfunction message.
Any pointers ?
Thank you folks !
Any pointers ?
Thank you folks !
thank you
