Sponsored by: CARiD
E350 M276 fuel consumption
Old May 21, 2023 | 03:33 PM
redaotrosh's Avatar
W220 S320 99, W212 E350 2014
After 1.4 k miles in 2 and a half months my computer consumption shows 21.3 mpg, combined between highway, hills and short trips stop and go. Around 30 percent highway and 30 percents hill up and down and the remaining city stop and go.
For example moving about 100 miles trip( 50 going and 50 coming back) which is 23 miles highway 65 mph, 5 miles city and traffic light below 40 mph, 17 mile highway then 3 miles traffic. I got in this trip around 27.5 ~28 mpg.
Another trip will be moving up around 23 miles from 0 meter to 950 meter in one hour. I got 20 mpg. And so on.
Engine fluid was used as previous owner 10w40 no idea what is it, as last friday changed fluids at dealer to MB specs.
Is that normal numbers for this engine and is the oil types affect on consumptions so maybe I will get values after changing engine and coolant fluids to MB specs.
As I have reset the computer after fluid replacement and monitor it for coming months.
Old May 21, 2023 | 04:14 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
nearly good
These numbers are slightly not the best but not too bad either. I'd say you're on the poor end of average.
Check that all 4 of your wheels turns freely without brake calipers binding (eventually lubricate slide pins).
Check tire wear patern for signs of wheel issues. Vehicle height and load directly affects the alignment toe and roll forces required.
Old May 21, 2023 | 04:32 PM
chassis's Avatar
2017 GLE350 4MATIC
These are the correct numbers. I never managed more than 21mpg in a GLE which has larger frontal area and is heavier than a W212. Each driver has different driving styles, routes, conditions and fuel sources. You are in the realm of normal with this engine.
Old May 22, 2023 | 11:01 PM
zenocchio's Avatar
2011 E350 wagon, 2014 E63S Wagon
On my 2011 E350 s212 I am getting 7.3km/l or 17mpg, averaged over the past 20,000km. It is almost as thirsty as my old s212 E63s
Old May 23, 2023 | 03:07 AM
redaotrosh's Avatar
As my W220 E320(200 Kmiles), I am getting 17 to 18 mpg combined while in a highway trip I can get 23~24 mpg so the W212 performs better in consumption but when you checking wikipedia numbers for E350 as it will perform 34 to 30 mpg made me confused.
