Sponsored by: CARiD
My start stop got weak.
Old May 28, 2023 | 03:25 PM
tab2050's Avatar
e220 w212
my e220 from 2015 has started to become weak in start stop. When I stop at a red light, it cannot start again after releasing the brake. It has started to do so more and more over time. But only do it sometimes. It starts fine if you turn the key back and start it again. my battery is fine too. Since it is a taxi that runs for many hours. But what could be the cause? sometimes it is weak to restart and sometimes it can't. It only does it at start/stop. ?
Old May 28, 2023 | 03:46 PM
chassis's Avatar
2017 GLE350 4MATIC
Time for new main and aux batteries. Battery tests mean nothing.
Old May 28, 2023 | 04:21 PM
tab2050's Avatar
e220 w212
the battery is 3 years now. But i can start after 1 day. Its only sometimes when its start stop its give problem. And its go green on eco mode. But do you think i have to change the battery?
Old May 28, 2023 | 04:27 PM
chassis's Avatar
2017 GLE350 4MATIC
Change 2 batteries: the main battery and the aux battery.
Old May 28, 2023 | 04:41 PM
DFWdude's Avatar
2016 E350 Sport
First, RECHARGE the main battery, then drive to test.
Old May 29, 2023 | 09:59 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Very interesting symptoms. The ECO start-stop system is not supposed to turn off the engine if there is a remote possibility of not being able to restart.
if the car is starting OK manually, but not automatically there is something subtle on the ECO system. As mentioned above,
- first recharge BOTH batteries,
- properly test the batteries ( voltages mean nothing for proper starting power -> LOAD test them ).
- Check ground wires on : main battery, auxiliary battery, starter ground strap, others in the trunk, passenger/driver footwellls
- scan for codes, note them, delete codes, test drive
Old May 29, 2023 | 05:37 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Flashware near you
if the car is starting OK manually, but not automatically there is something subtle on the ECO system. As mentioned above.
yep, that is 100% spot on Juan.
ECO rule No1 is no shutoff without proven battery power. The Bosch ECU is the best thing there is in the world!
Why does this engine fail to restart ...?
There's a TSB about that condition - Check VIN if range is applicable!
I recall it's a logical software bug.
Repair will/may require dealer to flash update to ECU over connected Xentry. Of course, Peter the @BenzNinja can do all that super well for you.
It maybe something additional as well... so use a descent scanner to retrieve your fault codes.
Learn to display your live voltage on w212 dashboard... above 12.6V ??
For free instant joy...:
you can indulge in CAR REBOOTS.
Old May 29, 2023 | 07:39 PM
Chevota's Avatar
E550 Coupe 2wd (2016)
My Eco start/stop apparently stops working if the batt is not good. Not sure if it bases it on static voltage, cranking voltage, starting current draw or what, but it seems to know. And my Eco stopped working a year before the battery actually gave me trouble. New batt and Eco came back instantly. I have little faith in the electronics to actually work right so don't assume that an operating Eco means your battery is good. Since it starts fine if you turn the key it tells me electronics are the problem. What exactly is the problem would be interesting to find out, but at what cost, assuming you are not under warranty.
So while I hope you can find the issue and fix it at little cost, it seems to me that turning Eco off is the easiest fix. I dislike Eco and it's just asking for problems imo. Like you're experiencing, plus you're annoying those behind you when you have to fumble to start the car. What worries me more is starter motor and battery life, especially in a Taxi! Price a starter and compare that to how much gas you save using Eco. I do my own repairs so it would be a fraction of the cost, but I'd still be extremely unhappy if it died thanks to over use by the Eco function. Or if it failed to start on me one single time I'd say that negates any bennies over the entire life of the car. Even if it always worked and the starter lasted forever, I find the Eco function super annoying. Plus I enjoy my AC. So after I start the car I turn that thing off first thing. I'm assuming you have a button to turn Eco off? I think we all do but just a guess?
Please post if you find the problem/fix, both for others who have it and our (my) curiosity.
Old Jun 2, 2023 | 01:18 PM
yyce400's Avatar
E400 Wagon
FWIW, when I was having issues with stop start and was getting error codes for random systems, I pulled the aux battery and it measured at 12.7, which is perfectly reasonable. However once I put in a new one they all went away. Don't trust the readings.
Old Jun 2, 2023 | 01:41 PM
JCM_MB's Avatar
Careful with those conclusions. A battery reading of 12.7V is just saying it is charged, it says absolutely nothing about being able to deliver the requested amperage when demanded by the system load. That measurement is done with a load tester, and measured as Cold Cranking Amperage. You can have a battery reading 12.7V and 100CCA, basically dead, and a new one in perfect condition 12.7V and 800CCA. Same voltage reading, VERY different CCA.
Conclusions can only be made using the correct metrics.
Same goes with the alternator. Measuring 14.5V at the battery posts means nothing if the current towards the battery is negative, i.e. discharging. An alternator is measured by its capacity to define the potential/voltage, and its capacity to deliver charge, i.e -> Positive Amps when loaded.
Old Jun 2, 2023 | 01:47 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
We can use tons of coffee grinds trying to forecast the problem, but the truth is that dealing with computers will not go far without good scanner.
Even my $50 scanner has troubleshooting page, who will show all parameters needed for the function, highlighting those having problems.
Old Jun 19, 2023 | 05:59 PM
Tab007's Avatar
w212 E220
Hi. I changed the main battery 6 days ago. Its seen to start stop works normally again.👍 I didn’t test the battery anyway. just ordered a new battery and replaced it. But i will test my start stop at more time and then let you know.
Old Jun 19, 2023 | 10:17 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
The same ones that screwed the diesel passenger car market in the US, thanks bosch.
Old Jun 19, 2023 | 10:23 PM
JCM_MB's Avatar
You are referring to VW Dieselgate?
Old Jun 19, 2023 | 10:30 PM
Quint22's Avatar
Veteran: Navy
Yeah, pretty much the end for diesel passenger cars. Truck and vans ok but they killed the aftermarket tuning scene.
Old Jun 19, 2023 | 10:39 PM
kajtek1's Avatar
The diesel market in USA got screwed at the time, where excellent diesel Peugeot were here in showrooms.
"For some reasons" USA did not import excellent turbo diesels, who were hits in Europe. The NA models of the era lacked HP ,so were too annoying. That was 40 years ago
Than a generation ago - Europe had whole series of "3l cars" who would make 100km on 3 liters of gasoline.
= 78 mpg.
Who in this country won't let the citizens to drive economy cars.?
Old Jun 19, 2023 | 11:03 PM
Quint22's Avatar
Veteran: Navy
= 78 mpg.
Liberals/misled environmental groups and oil companies ...... funny supposedly two worst enemies but the same when it comes to that subject.
Those other vehicles you speak of I understand were the pre emissions vehicles which if they would have just thrown a cat on would have been fine. Early 2000s diesels were actually higher HP here in the US. Many issues that play into this whole drama. US looking for HP gains when the market was young, then when they are looking for mileage about the same time dieselgate occured along with the extreme emissions components among other things. Whole big fubared mess. Oh and most all of the other countries have limited to basically no emissions standards with sulfured diesel and all that yet EPA and CARB destroys the US market because that will make a difference when no one else is doing it besides one or two places.
Old Jul 11, 2023 | 09:59 PM
Tab007's Avatar
w212 E220
After some weeks of time.
My car stil don’t start some time at start stop and now its happening more than before. I have ask one mercedes mechanic and he says you have to change the starter. So it was not the battery that i have replaced. I will get my starter changed and c.
Old Jul 23, 2023 | 12:59 PM
Tab007's Avatar
w212 E220
A few days ago, my car completely stopped starting. It stopped in the middle of the road. the starter had gone. I have now replaced my starter and now it works perfectly again. It wasn't the battery at all as claimed at the start of this thread. I had a new battery replaced which was not necessary.
Old Jul 23, 2023 | 01:19 PM
DFWdude's Avatar
2016 E350 Sport
Trust us, your main battery was shot, too,
Old Jul 23, 2023 | 02:20 PM
battery + starter
Hopefully it keeps starting with ECO enabled as expected.
I don't think we can say W212 are plagued with poor starters. They are suposedly built 5x stronger for ECO cycles.
Anywho now, your car is all good to go again !
Old Jul 23, 2023 | 11:38 PM
Quint22's Avatar
Veteran: Navy
It seems they were linked essentially. Many things on these modern vehicles will act up or go bad with a weak or bad battery. It seems it was necessary as it fixed your problem for a bit however the starter didnt servive the weak power it was receieving.
If your aux battery is the same age as original main I would probably replace that as well.
