Oil change using Fluid (oil) extractor versus not
#77
SPONSOR
11 E550, 16 AMG GTS, 13 S550
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Service Manager/Owner
Amsoil Independent Dealer #7236674
#78
Received 1,001 Likes
2010 E350 4Matic
I should add I did use my mitivac pump with warm oil this time and it pumped well but wouldn't hold a vacuum so I had to pump every bit out. I got 8 liters out.
Edit: Just confirmed the pour the oil in the filter housing method. Works fine. The drainage flow rate is a little slow but that is a small price to pay for the built in funnel. You just have to be patient when you check the oil level.
One nice thing about using the extractor is there is one less opportunity for introducing a leak or loss of oil.
#79
SPONSOR
Yeah the mityvac is a chore to use but its still convenient when it works
oh **** i never thought to just do it that way
yeah you can basically just leave it in for a decade and itll be fine, some people even have re-used the washers for multiple oil changes.
__________________
#81
I bought one of these to change the oil on my boat (twin volvo turbodiesels) that had no room under oilpan to to drain the oil, it works great for my cars, I can just get two oil changes in it before having to dump it.
https://www.westmarine.com/west-mari...-14557417.html
![](https://www.westmarine.com/dw/image/v2/BGFG_PRD/on/demandware.static/-/Sites-wm-master-catalog/default/dw51a01795/images/orig/14557417_1500.jpg?sw=800&sh=800)
pierrejoliat (07-18-2023)
#83
pierrejoliat (02-19-2024)
#85
Edward
#86
FWIW, the concern that not all the old oil being removed is a wholly unwarranted concern. Though I'm relatively new to MB, I'm an old 911 guy, and we've all been doing oil changes that leave copious amounts of oil still in the system: engine in back, oil cooler in front (some cars two coolers), all the lines ...yeah, lots of oil you're not draining. Never an issue over many decades from our aircooled beasts! My 350 has a ~8qt sump so yeah, I ain't worried about whatever bits are left in every galley throughout the engine.
Edward
#87
SPONSOR
Regarding the last bit of oil being removed, even if you leave an ounce, oil starts to lose it's volatility resistance as it degrades, if its just a tiny bit it would usually just burn of and get fired out the back while the fresh stuff continues to work for you. The normal oil pours for these cars in my observation usually start cooking off at around 7500, so as time goes on that residual in theory really to be in there anymore
__________________
The following 2 users liked this post by ChrisHimself:
pierrejoliat (02-19-2024),
Raj1471 (07-18-2023)
#88
2010 E350 4Matic
What is your measurement system for this observation?
#89
SPONSOR
at around that mileage in my area, when going to the 10k OCI, it's pretty normal to start topping off
i'm aware that other people don't top of fall the way to 10k in other locales, but it's commonly accepted to lose .5-1qt between oil changes with the factory pour. That and I see what comes out of these and have a pretty sizeable sample size. Anything I say here is anecdoctal though. I don't exactly do write-ups.
we're also kind of a performance shop.. so our peoples' driving habits tend to be a little spicy.
__________________
The following 3 users liked this post by ChrisHimself:
#91
SPONSOR
you know where to find me if youre tired of topping off..
__________________
#92
2010 E-350 4-Matic
I just bought the OEM pump and this adapter - the metal part male end fits into the dipstick, but the female side is a lot wider than the larger of the 2 hoses that came with the extractor...
Actually, although the female end is wider, the tube will push into the narrow neck and seal fine.
#93
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Received 1,753 Likes
2016 E350 Sport
Last Summer I bought one of the Holt pneumatic oil extractors from Harbor Freight Tools. (See post #51)
https://www.harborfreight.com/pneuma...tor-57056.html
I intended to couple the new extractor to my existing air compressor...
https://www.harborfreight.com/2-gall...sor-64596.html
My oil was not due for changing at the time, so I waited until a warm day last week (mid Feb). My old Mityvac manual pump was a chore to use because with repeated uses, the suction became less forceful, requiring constant hand-pumping with the handle last time I used it. But this new one worked wonderfully. It extracted all but a teaspoon of oil. (I use the acquarium tube all the way down the dipstick tube method.)
What used to take 20 minutes of manual pumping with lots of effort with the old unit was done in less that 10-minutes. I am very pleased. HTH...
The following 3 users liked this post by DFWdude:
