Sponsored by: CARiD
E550 engine mount part numbers
Old Jul 5, 2023 | 06:23 PM
RDE38's Avatar
2011 e550
Hey everyone, I'm a bit confused with the oem options for motor mounts for my 2011 m273 e550. I pulled the pair from the car and they both have the A 204 240 10 17 part number. I see that this part number has been replaced over the years but now they seem to be side specific. 2042404417 is for front left and 2072400417 is for the right. What sense does this make? Are they really side specific now? FCP euro still has the original 2042401017 on their site but now i'm curious if I should order the updated versions from the dealer.
Old Jul 5, 2023 | 10:03 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
This is what I bought for my diesel.
Such parts should be bought only from suppliers who check the fitment with your VIN.
212-240-64-17 Front Mount $225.061 $225.06
212-240-63-17 Front Mount$222.641 $ 222.64
Old Jul 9, 2023 | 12:07 PM
Creative Steel's Avatar
SPONSOR
AMG's, CTS-V's, SRT's
Part numbers will get changed as "improvements" are made to the design or if Mercedes switches its engine mount manufacturer. Mercedes is now switching over to left/right specific mounts because they are valving the two sides differently. This is an internal part of the mount that you do not see and from the outside the two mounts will be identical. Now these changes are questionable for longevity but that is the rundown.
If you are looking for a more permanent solution so you dont ever have to replace them again, check out our Elimivibe engine mounts here - https://creative-steel.com/shop/merc...-engine-mounts
Old Jul 18, 2023 | 10:47 AM
RDE38's Avatar
2011 e550
For anyone looking in the future, apparently it’s two of the 204240441764 mounts. What a pain to replace though. Probably took about 8 hours total. I ended up lowering the front subframe about an inch to get the extra clearance I needed.
Old Aug 23, 2023 | 11:53 PM
HDCE500's Avatar
2010 E500
I too have been finding it tricky to locate an accurate part number for the W212 M273 mounts, some say V8 only & then others say they overlap with a V6 (FCP Euro). But the V6 mount part number I search for doesn't match to the M273.
Given that it'll be easier to source these from overseas (I'm in Australia) I need to make sure I get the correct ones.
Is the part number (204240441764) you used suit the NON-4matic version? I have the rear wheel drive sedan, so already I think it's a little easier to fit new mounts compared to the 4matic cars.
Thanks.
