Sponsored by: CARiD
Sunroof
Old Aug 22, 2023 | 07:50 AM
BenzW212's Avatar
Mercedes E class E300 BT hybrid
Sunroof
Hi. My concern is about Mercedes Benz E300 W212 sedan
I am having issue with my panoramic roof. The curtain close but does not opens nor do the sunroof tilt or opens.
* Panoramic roof needed greasing service but couldn’t reach that in time. Could be the reason or could it be something else.
Old Aug 22, 2023 | 08:01 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
In MB models, the sunroof has a safe mode where it disconnects and it stops working. Usually, it needs to be reset either via scanner or by just removing the fuse for a minute.
Check fuse 17 in the front fuse box next to the engine
https://fuse-box.info/mercedes-benz/...uses-and-relay
If it starts working, please do the required maintenance or it will stop working again, or it will get worse, $$$
Old Aug 22, 2023 | 08:07 AM
BenzW212's Avatar
I have tried to remove the fuse 17 in the engine bay and plugged in again no results. Even the fuse wasn’t damaged.
