2011 E550 battery losing power
MY'14 W212 M276 3.5NA @60kMi
dess (09-01-2023)
batt or starter
You want to use a DC-Amp-clamp to prevent disturbing the sleep you are trying to observe.
If you drive 8Hrs and the battery cranks slow after a 1Hr stop and the battery is tested ok... then you have a marginal starter brushset - One of the 4 starter brushes is worned out short forcing current into only 2 brushes circuit. We'll see...
BINGO !!
Are you suggesting I buy a new battery?
It is a few years old, but I replaced it because it was doing the same thing with the old one. Didn't improve much (maybe lasted a little longer between the need to recharge).
After the battery, I replaced the voltage regulator in the original alternator, after it didn't fix the issue, I (2-3 years ago) replaced the alternator (with a used one from a very low mileage car).
That iproved the situation, but never fixed it completely. This week i replaced the voltage regulator of this alternator and didnt fix the problem. If you think the battery should be replaced, I'll do it.
(Batt + Alt are off the short list).
Buy an OEM starter brushset or a complete starter unit.
Do cross reference proper P/N
For reference what is your mileage?
My mileage is a little over 140k, but the starter was replaced about 20k miles with one from a vehicle with 60k or so (if the yard was honest). Do you thinknthat the Bosh brush set would fix the possible issue with the starter?
double up bypass
> Free quick test:
Use your "jumper cables" to bypass chassis strap.
Here's how:
-- Connect black side to the chassis brass post (-)
-- the other end of black side cable to engine metal
(leave the Red side cable unused).
This setup is providing unquestionably good GND path for a normal starter to crank reasonably well.
Do you notice any speed difference with strap bypassef?
JCM_MB (09-01-2023)
#32
I measured it using a multi voltage meter connecting to negative terminal and to clamp. I measured it when the car had been sitting for a while (with the engine shut off) after I started the engine for a minute, not aware that it matters how long it's driven.
When you disconnect the negative to connect the tester, doesn't that wake the modules up?
Yes, loose power for a mere 2 seconds from ground or positive cable at battery post, the modules will power down and will wake up again, like a bad reset.
Anytime a battery is disconnected, often there will be DTC too, because some modules may wake up faster or sleep a bit slower as such when one of a known module is OFFLINE due to powerloss, the other modules
will think it is a fault condition. Later within seconds when the OFFLINE-ded module wakes up and all good, the DTC will then become STORED one, no more CURRENT one.
How I do it to not loose power is here : https://mbworld.org/forums/e-class-w...-your-car.html
#33
Still not charging properly, but have realizations
So I just realized that my alternator charges my battery (between 13 and 14v is the norm) and runs properly during the winter months and I don't have to plug it in at all during the winter. As soon as the weather gets warmer, the voltage goes down to 12v or below and after a few days, I have a very slow crank, followed by requiring a jump. Is there something I can do to trick the computer to charge the same way it charges during the winter? Otherwise, I have to charge the battery at least once per week so I don't risk the embarrassment of jumping my car on the street.
#34
CANCELING BATTERY CHAOS
-- you can simply drive with headlights:ON
-- or you can research how to disconnect the ALT LIN
-- or you can try to fix factory painted GND posts
Do the above and keep monitoring your dashboard battery stats.
Let us know what's best.
